SM465 gear oil?????
Discussion in 'The Garage' started by RingMaster4x4, Feb 25, 2005.
  1. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    what gear oil is best for a SM465? I put 85w-140 gear oil in my SM465 and now I can't down shift it 1st. (not Low) Or is this something esle? I could down shift before I changed gear oil. (from the water that was in it.:mad: )
  2. rcurrier44
    rcurrier44 1/2 ton status
    Oct 13, 2003
    320
    I just use regular old 90W
  3. goldwing2000
    goldwing2000 Guest
    Usually 80W-90 in the tranny and 85W-140 in the t-case (NP205).
    I'm sure you'll get somebody to argue about that, though.
  4. diesel4me
    Jul 24, 2003
    17,540
    931
    Massachussetts
    80w90
    I'd use 80W/90 gear oil,I tried 85W/140 in my 72 K5's SM465 and I almost broke the shifter off trying to get it into first on frigid cold mornings near or below zero!--and when I put it in neutral and let the clutch out,you could feel the truck try to go forward,like fluid drive!--In canada they use 80W gear oil or a lighter weight synthetic for easier shifting...another truck I had with an SM465 tranny that was noisy I put 2 cans of STP gear oil treatment in it--same thing but worse--too thick to shift it in cold weather--it did quiet it down a lot though..:crazy:
  5. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    Sounds good thanks for the help. I will try it and see what I get.:thumb:
  6. Mule man
    Mule man Registered Member
    Feb 14, 2005
    28
    Arkansas
    I put some 75W synthethic gear oil in my 465 and it made it much easier to shift--especially in cold weather (20 degrees in Arkansas:))
  7. stock93
    stock93 Registered Member
    Feb 18, 2004
    68
    Huntsville, AL
    IIRC, my chiltons says to use dexron 3 atf in my sm465 in my 83 model. Does anyone know why?
  8. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Is it rebuilt or what? Put 30WT init.
  9. dyeager535
    26,977
    I wouldn't be surprised if it wasn't for economy. The 205 went with ATF later on as well...from what people say on here, you see more wear on the ATF fed 205 than you do with gear oil, so it can't be for better lubrication. MIGHTo have something to do with shift ease, but not sure about that, I have a feeling no matter whats in it, the 205 is just a pain to shift sometimes.
  10. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Ringmaster - I haven't heard negative comments on Redline MTL. It's a synthetic 75W gear oil that apparently is the cure of choice for difficult-shifting trannies.
    From the trans gurus at my former employer:
    A gearbox (manual trans or T-case) has to be designed for ATF lubrication to get maximum lifespan. The tolerances between gears has to be a little tighter, and a pump is needed, since ATF doesn't "climb" like gear oil does.
  11. JonV
    JonV Registered Member
    Mar 17, 2003
    27
    Hesperia, CA
    SM 465: 1987-50
    SAE 80W, 80W-90, GL-5
    in Canada 80W GL-5
    Capacity 4 quarts
    Transfer case:
    1981-89 All AF3 (Dexron-III)
    1973-79 NP203 Full Time 10W-30, 10W-40 SE (engine oil)
    1960-1980 all others, 80W, 80W-90, GL-5 (gear lube)
    Capacity
    1970-89 NP 205 5.0 pints
    I live in the Mohave Desert. Gets hot here so I use straight 90W (ISO 220) GL-5 in the tranny and transfer case. I use ISO 320, GL-5 in the diffs.
    If you have a limited slip, don't forget the additive.
    :cool1:
