SM465 guys
Discussion in 'The Garage' started by 454k30, May 24, 2006.
  1. 454k30
    454k30 1/2 ton status GMOTM Winner
    Sep 13, 2004
    1,613
    California, MD
    For those of you who have rebuilt this transmission; How many man hours did it require? I am not in any sort of time crunch so any information about time required, and also where you sourced your parts would be appreciated.
  2. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    are you sure yours needs rebuilding??? I still have the original in my truck and id say it has well over 500,000 miles... I bought it with 465k+ back in 1991 and that was 15 years ago!!!!
  3. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    If you are taking all the way down ( as it should be done ) and replacing the bushings on the mainshaft it will add an hour or so to the build . Plan on a good half a day if the tranny is on the bench and you are mechanically skilled with a good tool source and puller/press set up.
    Tom
  4. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Took me 7 hours and a case of beer. I also did a NP435 and NP205 @ the same time and they took about hte same time, just more beer since they came out of a Furd
  5. yoshisv
    yoshisv 1/2 ton status
    Feb 19, 2006
    266
    Hartsville, Tennessee
    I just purchased a rebuild kit for my 465 from Anaheim Gear. I also bought the heavier springs and a cluster spacer to keep it from jumping out of third gear. I beleive it cost about $300 total.
  6. lamberthkp
    lamberthkp SITFU Premium Member
    Jan 17, 2005
    1,468
    16
    West TN
  7. 454k30
    Sep 13, 2004
    1,613
    California, MD
    My transmission has had a hard life underneath a farm truck leaks from quite possible every seal that it has. I don't know if the bearings are still good but since it will be torn apart anyway...
  8. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    Got my rebuild kit from novak and it took me about 8 hrs to do it. Pulled tranny/t-case and washed it Friday afternoon, rebuilt on Saturday, installed on Sunday
