SM465 Hard down shifting from 2nd to 1st
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by yunit, Apr 1, 2001.
  1. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    SM465 Hard down shifting from 2nd to 1st. Is this natural with this trans or is there something wrong with the syncro's? It does not grind or anything down shifting into 1st, but I gotta really pull on her to get it in.
    1978 K5, Palisades Park, NJ 07650
  2. Brians 60s
    Brians 60s 1/2 ton status
    Jun 12, 2000
    1,115
    Bend, Oregon
    it's natural. first, granny gear does not have a syncro. you almost have to be stopped to go into first
    "IF YOU'VE NEVER BEEN STUCK.....YOU'VE NEVER BEEN WHEELIN"!!!
  3. yunit
    Feb 24, 2000
    3,068
    Oakland, NJ
    I actually mean 3rd to 2nd, not 1st to Low. Sorry if you thought the other way.
  4. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    Totally natural. Even the Ford 4speed equivalent NP435, I think, shifts the same way. No big deal.
    '73 K5
    Chevy good...Ford bad
  5. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    So does mine. I think its a gear ratio spread thing. I think the ratios are; 6.5 low- 3.5 1st- 1.5 2nd- 1.0 3rd, or close enuff to get the idea.
    Twiztid
  6. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    I've had good luck with an additive called Gear Guard M (w/moly) on my hard shifting motorcycle. Haven't tried it on a truck yet. It kinda expensive @ $20.00 a quart but that should be enough to do the transmissision and transfer.
  7. tRustyK5
    Jul 23, 2000
    36,184
    1,392
    E-town baby!
    I've got to be doing under 15 MPH to downshift to second on mine. Sometimes if I double clutch it will go in a bit easier. As far as I know this is perfectly normal. I've had three of these tranny's and all did this.
    Rene
    [​IMG]<A target="_blank" HREF=http://jules.coloradok5.com>http://jules.coloradok5.com</A>
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    My 82 K30 does the same thing. I even tried down shifting while the brakes were applied HARD, and sliding, while on mud. That works, but when I let off the clutch, instead of the tires spinning along with the speed I was going, they kind of "braked" the truck to a slower speed and almost like skidding in the mud.
  9. nyyef
    nyyef 1/2 ton status
    May 16, 2000
    479
    Saudi Arabia
    totally normal. someone gave me a general rule to follow.......the beefier the tranny, the harder its going to shift (especially downshifting). thats why the little rice burners have very light and smooth shifting trannies.
    on one of my old trucks i tried something, i modified the brake and accel. pedals so i could heel and toe them. that way you easily blip the accel pedal when you are on the brakes for easier shifing.
    but i did such a crappy job, and did not do it on my current rig.
    Knife.
    knife.coloradok5.com
  10. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    Yup, normal, helps if you give it a little gas to match the rpms of what ever gear you'll be going in when downshifting. ie, clutch and brake, slip off brake give a little gas and slide it in gear, brake some more or drop the hammer.
  11. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    yes this is very natural
    77blazer see it at<A target="_blank" HREF=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</A>[​IMG]
  12. Logan
    Logan Registered Member
    93
    Fournier, Ontario, Canada
    Mine does it too...
    Annoying as hell, since there's a big power hole there... Coming up on a sharp turn followed by a hill.... You know you should be in 2nd, your engine *really* knows you should be in 2nd, but the tranny's convinced that 3rd is just fine. You get to choose to take the corner too fast, or way too slow. I think big tires/improper gearing throw it way off, too.
    Every standard car/truck I've ever driven has something in the tranny that makes it hard to shift into 1st (2nd in this case) while you're still moving... Still, if there was a way to get rid of this 'feature', I probably would. It's the only thing I really don't like about my truck.
    -Al.
