SM465 Hydro conversion help/tips experience?
Discussion in 'The Garage' started by TopOff, Apr 21, 2002.
  1. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    OK, I got a '73 Blazer with Howell TBI 383.
    Woohoo The doubler buidlup begins
    Time to ditch the TH350/203 and install a SM465/203/205 .
    I still need a flywheel and clutch.
    I have the OEM bellhousing, but just for FUN I called the local wrecker and asked if he has a Hydro setup!... He said he does!!! HOLY COW, I SAY I am coming down! He said, no I am closing. I said, OK Monday!
    Any tips on installing a Hydro setup in a 2nd gen?
    TIA
    TopOff
  2. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    Get all the parts you can. The pedal hangers (for brake and clutch) Clutch master, slave cylinder, all the lines...
    MJ has a complete parts list. you might want to send him a pm...
    Rene
  3. TopOff
    Jan 16, 2002
    1,760
    Folsom, ca
    The guy at the yard, said he will hook me up. I requested the bell, slave, master, pedals, and line... do I need BOTH Brake and MASTER pedal and assembly?
    I already have the brake, clutch pedal assembly from the previous years...
    TIA
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    yes.
    you will have to do some work to mount the slave.
    I swapped to an 87 cab and it has the mounting indents for the slave that i really doubt the old cab has.
  5. TopOff
    Jan 16, 2002
    1,760
    Folsom, ca
    Would this just be a question of drilling some holes for the mounting of the pedal assembly?
    Or drilling some holes for the master clutch rod to come through the firewall?
    TO
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I think the pedal assembly should bolt in.
    the slave mounting will be hard part.
    it sits at a real odd angle, under the brake booster.
    would be a good idea to hit the wreckers and compare some stripped cabs firewall area to see what you are up against.
    if anyone had a bare cab to shoot pics of that may come in handy,
    you may even be able to cut the slave mount out of a cab and splice it in.
    would be a good time to swap in a rust free tub
    the cab i swapped in was a 2wdr auto so all the firewalls after 85ish have the slave mount indicated
  7. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    MJ, Can you post your link to those pics and GM part numbers again for the clutch pedal assembly and stuff...Thanks man...
    Chris
  8. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    <a target="_blank" href=http://community.webshots.com/album/13180252EPlFnPcEPJ>http://community.webshots.com/album/13180252EPlFnPcEPJ</a>
    I will see if I can shoot a pic of slave mounted
  9. TopOff
    Jan 16, 2002
    1,760
    Folsom, ca
    Thanks for the info all.
    Has anyone done this on an early chevy?
    TO
