sm465 hydro parts
Discussion in 'Parts & Trucks Wanted' started by nerraw117, Feb 26, 2007.
  1. nerraw117
    nerraw117 1/2 ton status
    Jan 5, 2005
    788
    charlotte, NC
    anyone have the pedal assembly for a sm465 hydro swap? i need brake, clutch pedal, support rod, pretty much everything to do a automatic to stick conversion except for tranny,t-case and bellhousing.
  2. tornado427
    tornado427 Registered Member
    Jan 31, 2007
    24
    Milan NM
    auto to stick swap
    if you cant find the stuff to go hydro, you can use the older linkage set up, all you have to do is rob the linkage pivot bracket off an older frame and drill and bolt it to the frame on your newer style frame. then you can use bell housing with the ball mounted on the side, tons of these set ups in junk yards, Doug:D
  3. Hazy
    Hazy 1/2 ton status
    Mar 24, 2006
    180
    CA
    i ordered a hydro kit from novak. and a universal master cylinder 7/8" from summit racing.
