SM465 Hydrolic Bellhousing
Discussion in 'The Garage' started by DuallyK5, Apr 30, 2006.
  1. DuallyK5
    DuallyK5 Registered Member
    Apr 6, 2006
    32
    New Jersey
    Does anyone know where I could possibly find a SM465 Hydrolic Bellhousing for a 1988 K-5 Blazer? I have the Pedal, Master and Slave Cylinder alone with the resivior. I also have the SM465 and the NP205 with the crossmember. Also if anyone has the SM465 Hydrolic Bellhousing even on there truck could anone possible get me the casting number? Also what else will be in the bellhousing besides flywheel, clutch, and pressure plate.?
  2. dyeager535
    26,979
    GM part number is 15530202, if you plug that into gmpartsdirect.com it comes back as $218.xx before S&H. A fair chunk of change, but for what I've seen used ones go for, that probably isn't super unreasonable for a brand new part.
    That number is *probably* cast into the bellhousing somewhere. Different than a casting number, but both, either or none of the casting/part numbers may be on them. Just depends.
    You can't mistake the hydraulic bellhousing though, it has an "ear" on the drivers side for the clutch slave cylinder.
  3. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    do a search for it on
    car-part.com
    I buy alot of stuff from there....
    online junkyards are so way cool....
  4. DuallyK5
    Apr 6, 2006
    32
    New Jersey
    Thanks for the information. That helped me out alot. I didnt think you could still get teh bellhousing but I was wrong.
  5. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    i believe it is advanced adapters that sells a kit to use a regular bellhousing with the hydro clutch. that could always be an option
