SM465 I.D.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Skroo, Nov 8, 2002.
  1. Skroo
    Skroo 1/2 ton status
    Jul 13, 2002
    137
    Houston, Texas
    I'm going looking for a 465/pedal set-up tomorrow and need to know what the I.D marks are. I know that it is really short but are there any other trans that can be mistaken. I need one for a np208 so if I find a two wheel drive trans, what years should I look for(besides the splin count) if I can grab an adapter? And last what year did GM start using the hydro clutch?
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    This is a good page for SM465 info:
    http://www.novak-adapt.com/knowledge/sm465.htm
    First off, you better have a TH400 in there now. The TH400 and SM465 use a 32-spline output shaft, and thus, have a 32-spline NP208 mated to them. A TH700 has a 27-spline output instead. If you have a TH700, you will need to swap the input gear on the NP208, or just get an complete tranny/t-case.
    The SM465 you need has a long (10" or so) output shaft with 32-splines. You also need the SM465/NP208 adapter. This narrows your search down to an 81-87 1/2 or 3/4-ton pickup - or a 81-91 Blazer/Jimmy/Suburban.
    The hydraulic clutch started in '85. It uses a different bellhousing from the mechanical linkage variant.
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    better yet,
    get a matching tranny transfer case combo that is all bolted together rather then buying them seperate.
  4. Skroo
    Jul 13, 2002
    137
    Houston, Texas
  5. Skroo
    Jul 13, 2002
    137
    Houston, Texas
    Update
    I just got a deal on a 82 for less than cheap. I could pull the trans, clutch pedals, and linkages and part out the rest and get my money back. Could I just change the output shaft to a long 32 spline and find the correct 208 or 241 with the adapter? If I do this will the drive shafts be the same length?
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    82 will be the long 32 spline already if is 208
  7. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    for future use- the SM465 has 465 stamped on it.
