sm465 in 88 blazer
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Chaz88K5, Jul 20, 2001.
  1. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    ok since i dident get any bites on the 700r4 trade....i guess i have to do it the hard way...dose anyone have any clutch pedels and all the other required parts to convert over to a manual tranny for a 87+ blazer/pickup? I have the tranny already so i just need the pedels, slave cylinder, and master cylinder for clutch....can anyone help me out here...or if you can still get the parts at the dealer dose anyone have the part numbers?
    Donations accepted for the "Build Chaz's 1972 K5 fund"!!!
  2. dyeager535
    26,982
    191
    I can get you the part numbers, but you are going to be in the $400's easy if I remember correctly. You are having a hard time finding these because that hydraulic clutch setup just wasn't that common. You know that one out of any Chev truck our body style would work, right?
    Personally I'd hold out for the hydraulic stuff, but you could fit the manual linkage in there as well. As long as you can wait, do. Its worth it.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
  3. Chaz88K5
    2,979
    Stockton/Lodi CA
    i dont want the manual linkage in there...too much hassle and i dont want to have to be adjusting it all the time......so it would be great if you could get the #'s for me.
    let me know
    Chaz
  4. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    How would the newer 5spds from like 93 and on fit in there? That's what I'm thinking about. Prolly lots of those in the junkyards. Or one of the new auto trannies they're putting in the Chevy 3/4 tons and 1 tons. Starts with an A.....
    I'm rambeling....[​IMG]
    I've got a mind like a . . . a . . . what's that thing called?
    <a target="_blank" href=http://www.geocities.com/muddin4fun79blazer/>http://www.geocities.com/muddin4fun79blazer/</a>
  5. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Allison is the name of the new tranny. I have one in my truck. Simply awesome. PTO Capable too.
    '83 GMC Jimmy 4x4 ZZ4 Crate Motor
    '83 Chevy K20 Sand Drag Racer, 578 RWHP
    '94 Impala SS
    '01 Chevy 2500HD 4x4 w/8.1L & Allison Auto
  6. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    PTO capable.....I'm assuming you're talking about the transfer case, or is the new Allison PTO equipped? Buy the way, what kind of transfer cases are they putting behind the Allison's
    If you didn't build it yourself, how can you call it yours.......?
  7. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    The Allison automatic has PTO provisions, but there is not enough room under the body of the truck to use it. Only cab & chassis versions have room. The HD transfer case is an NVG261 (manual shift) or NVG263 (pushbutton shift). The 261 is basically an improved, heavy duty 241.
    Tim
    70 Blazer CST 4X4 350 SM465 NP205
    87 Burb 4X4 350
    01 GMC 2500HD 4X4 Duramax/Allison
  8. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    i have all the part numbers, this is when i wish we could post images. can we get that back?
    pic legend
    http://wsphotofews.excite.com/014/j9/fv/QP/LZ21732.jpg
    the slave HAS to be removed from bellhousing and held at 45deg to bleed it. i bought all from chev dealer but junkyard would be better place to start
  9. Chaz88K5
    2,979
    Stockton/Lodi CA
    i just checked on www.gmpartsdirect.com and the total came out to 430.00 with shipping for everything on that list...thanks for your help!
    Chaz
  10. michaelm
    Feb 2, 2001
    872
    good pricing, i got stung over $300cdn for the bellhousing alone
  11. Chaz88K5
    2,979
    Stockton/Lodi CA
    just the bell housing is 143...so its not to bad at all
