sm465 leaking real bad
Discussion in 'The Garage' started by Jishory, Mar 9, 2006.
  1. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    seems to be leaking from several places, front main seal, top cap, tranny to adaptor seal, adaptor to t-case, are their gaskets for the top cap and the adaptor or is it best to use gasket maker?
  2. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,923
    333
    Fort McMurray, Alberta
    I complete gasket kit cost me about 5 bucks :)
  3. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Use gaskets and rtv together
  4. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    You could bolt down the top plate.. of course that would eleminate you quick removal shifter :doah: (:flipoff2: )
  5. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    Did you over fill it?
  6. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,229
    485
    New Hampshire
    yeah the previous owner of my truck put over 2 gallons of gear lube into the tranny. He must have filled it through the reverse light switch hole. The same thing happened to me with oil just seeming to come out of no where and everywhere at the same time.
  7. Jishory
    Jan 8, 2002
    1,367
    Palmdale, CA
    i think so, initally i poured a couple gallon jugs in the shifter hole, then i have continued to fill it up as it has leaked... :doah:
    im going to drain it and put a gallon back in, then wipe it down and see if it still leaks
  8. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    Don't drain it all out, thats not needed, just remove the fill plug(on the side of the case) ad let it drain out until it stops, then it is full:D
  9. stevos67k20
    stevos67k20 1/2 ton status
    Sep 29, 2005
    140
    Somis
    my 465 leaks like crap too....i filled it up to the proper level and it still leaks like crazy. when you fill up the trans does some of the oil go in to the transfer case? cuz i think mine did. i filled my transfer care and then my trans mission so i think it was way to full...key words "i think", not very reliable... :)
    speaking of 465 stuff, i always grind going in to third gear and now when i am idling in neutral, not moving, and try to go into 1st gear it grinds and i think i remember that there was somthing stoping that... idk.... well thanks for the view and responses...
  10. Jishory
    Jan 8, 2002
    1,367
    Palmdale, CA
    sounds like a plan, ill give that a try when i get to my truck tomorrow
    your trans can leak into your t-case
    have you tried bleeding your clutch? seems like when its grinding gears like that the clutch isnt depressed all the way
