sm465 linkage!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mudddog91, Sep 18, 2001.
  1. mudddog91
    mudddog91 1/2 ton status
    Dec 28, 2000
    471
    north carolina
    Has anyone had problems with their linkage binding or not engaging the clutch during Hi Tweakage type times?Whenever I get all crossed up and about to crawl over the next obstacle my clutch wont grab enough to allow for forward movement?I dont git it! I cant see haw theres much adjustment to this system either so what do I do?
  2. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    Mine does the same thing. I should have used hydrolics on the clutch instead of a manual one.Between the body flex and frame flex i have gotten stuck in some odd places because the clutch didnt work . i have even had the clutch rod slip off the fork before.
    A BIG HAMMER CAN FIX ANYTHING.. [​IMG]
  3. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    i actually broke off the piviot on my clutch, have had poblems making it catch, but don't know what to do also
    You know who I am
  4. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    The only way to fix it is to go hydraulic.
    Tim
    70 Blazer CST 4X4 350 SM465 NP205
    87 Burb 4X4 350
    01 GMC 2500HD 4X4 Duramax/Allison
  5. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I guess I'm lucky, i've never had my linkage do that and I get my rig perrty crossed up on the trail too! Shoot now that I said something I bet it happens!![​IMG]
    I had to replace my Zbar once cuz it craked and I had to learn how to shift with out a cluch to get home, that was fun! Shure did figure out how to feather the throtle that day!!hehehehe
    Ya some day I would like to goto hydrolic also...someday!
    <a target="_blank" href=http://www.geocities.com/baja/5099>www.geocities.com/baja/5099</a>
  6. harry
    harry 1/2 ton status
    Feb 9, 2001
    106
    san diego, CA
    I am too am trying to go with hydrolic. I posted a question on the 69-72 board and got a few answers. If you guys have any input on how you have done it and the parts you used, let us know.
    thanks,
    harry
    69k5
  7. Grim-Reaper
    7,385
    Atlanta
    Wilwood 340-1470
    ajax.extremejeep.com/mike/Pictures/slave.jpg
    That's done to a stock clutch fork that had mechanical clutch. That's a SM420 tranny in a internet buds jeep. The Slave is a pull type. You don't get into the oil filter clearence issues. Willwood also sels a clutch master that with some creativity you can make work on the fire wall.
    It's not my damn planet monkey boy!
    <a target="_blank" href=http://communities.msn.com/OffroadK5s>communities.msn.com/OffroadK5s</a>
    75 Jimmy, Dollar
    79 Chevy Blazer, Her's
    70 Chevy Burb
    Grim-Reaper
  8. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    My linkage occasionally binds up. One time, my clutch bound up at Mudstock in Potosi, Mo. I was at the Urban Rockcrawling Course and had drove the K5 up the front of a School Bus. I stopped just as the front tires reached the roof - to take photos. When I tried to disengage the clutch, it would not release. The truck kept going! Had to kill it, then get pulled off the Bus by another truck. My clutch was smoking the whole way as I was being strapped backwards. We finally got me down from the School Bus, then I tried a concrete culvert and had similar results. It was so bound up, I could not get it into neutral! Finally Bigdaddyof2 gave it a yank and it went into neutral. I didn't try any more that day! Found out the problem wasnt linkage, it was the pressure plate collapsed. So, pick up your latest issue of 4 Wheel Drive and Sport Utility magazine and look at the Mudstock coverage. There is a photo of a Jeep climbing the same Bus. Well, if my clutch hadnt failed, you would have been looking at my K5 on that Bus! The camera man was there watching, but never snapped a pic! Ill post photos sometime soon. Anyway, thats my story and I'm stickin' to it!
    Mudzer 1978/91 K5
    <font color=blue><a target="_blank" href=http://www.mudzer.rockcrawler.com>www.mudzer.rockcrawler.com</a></font color=blue>
  9. dyeager535
    26,976
    Anyone heard anything about the hydraulic throw out bearings? I would think that would be about the EASIEST way to go, yet I'm not sure if anyone here has gone that route yet.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
  10. Grim-Reaper
    7,385
    Atlanta
    Yeah Jeep has tried it and they fail all the time. To much heat in there it bakes the seals out of them. Then the fluid trashes the clutch. Seen one catch on fire this way. It was leaking but still working guy slipped the clutch enough to ignight the fluid.
    75 Jimmy, Dollar
    70 Chevy Burb
    Grim-Reaper
  11. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    I've had a little bit of bind in my linkage at times also. I think that Mcleod sells a hydralic throw out bearing setup but it cost a lot. Summit sells a hydralic cylinder that is a pull type that can be mounted to the trans. You have to figure out how to mount and work the slave cyclinder though. The last option for me was to go to an automatic. My wife won't even try to drive my 465 so I'll be selling it soon. Good luck.
  12. dyeager535
    26,976
    I'm sorry but that image is funny...burning clutch! Would be horrible, but yet that image : )
    Glad I got hydraulic already I guess, but I can't imagine myself crossing the truck enough to mess up the linkage. But thats pretty light duty off roading.
    Dorian
  13. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    i used all factory parts from 1985 chev truck
    including bellhousing with integral slave mount.
    quick n easy for me as i also replaced my cab with an 87 so there were indents where i needed to drill the firewall (cab was origonally 2wdr auto)
    scaned images of the parts required
    http://wsphotofews.excite.com/014/j9/fv/QP/LZ21732.jpg
  14. Mudzer
    3,639
    Missouri
    Thanks a bunch for those pics.
    Mudzer 1978/91 K5
