SM465 Loose Shifter
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ECNiz, Apr 18, 2003.
  1. ECNiz
    ECNiz Registered Member
    Sep 9, 2000
    54
    Santa Cruz, CA
    The shifter on my SM465 is a little looser than I would like it, I took the shifter out and noticed there is a lot of slack where the bottom shifter piece is held on by the pin. The outer hole is a lot larger than the pin and allows a lot of slop. what can I do to get rid of that slop? Would welding it be a good idea? Or how about drilling out the inner piece to match the size of the outer whole and using a bigger pin? Or does anyone have any other ideas?
    Thanks Guys!
  2. dyeager535
    26,975
    I'm looking at a chrome SM465 shifter handle right now.]
    The pin you mentioned on all shifters I have examined, is also not a good fit in that hole. It's either intentional on GM's part, or simply a wear area.
    The main part that I've noticed that causes problems is just "up" the handle from the pin you mention. The half round "ball" that the spring for the lock mechanism seats on, has a weld at the base of it. 3 out of 4 of the handles I have inspected have had broken welds here.
    The truck I've driven with that weld NOT broken, feels much "tighter" than my trucks shifter.
    But in reality, first off, these are not "precision" transmissions. They are heavy duty, and were NOT designed for fast, precise shifts. They are capable of DECENT shifting, some better than others though. Second, most newer trannies, at least for cars, are better designed for faster, smoother shifting, and use bushings and what not to achieve that "tightness". That "tightness" comes at the cost of weaker parts that wouldn't hold up as a truck transmission should.
    GM did put a "car" 4 speed floor shift manual transmission in these trucks, but it wasn't very common at all, and I doubt it was a very popular "option". I've seen exactly *1* truck so equipped.
  3. 79Jimmy
    79Jimmy 1/2 ton status
    May 10, 2000
    214
    Richmond BC, Canada
    I'm with dyeager on this one. 90% of the shifters I've seen on SM465s, the "weld" is cracked. I welded mine up which helped but it's still no Honda /forums/images/graemlins/smirk.gif
    James
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    there was a thread on this last year
