SM465 loosing oil
Discussion in 'The Garage' started by kennyw, Dec 2, 2002.
  1. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Over the summer I started noticing a noise from my 1979 K10 w/SM465 & NP205 on hot days. It would start around 35mph and would not quite till I slowed to 5 mph. Hotter days the worse it got. Sounded like a high pitch whine.
    Today I found the transfer case was over full and the transmission was low. Thinking back I think I first noticed the problem shortly after changing the fluid in both the tranny and Tcase to new 80W90 GL5 oil.
    At a minimum I believe the seals will need to be replaced in the tranny output and tcase input. Anyone know of other possible causes I should check for when I get them pulled out?
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    thee is only one seal between the tranny and TC.
    sounds like yours is bad.
    be very careful not to nick the new seal when mating the TC to the adapter.
    I have done this a couple of times and now I mount the adapter to the TC on the ground and lift them up to the tranny as a unit.
    more of a PITA then the other way but I have XXXXed it up twice now doing it the easier way
  3. kennyw
    Jun 9, 2002
    13,223
    94
    The easier way always seems to be more work in the end /forums/images/graemlins/smirk.gif Thanks for the tip /forums/images/graemlins/thumb.gif
  4. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    Let us know if it gets rid of the whine....I have the same one but my fluid levels seem to be fine.
  5. kennyw
    Jun 9, 2002
    13,223
    94
    The first thing I thought was causing the whine was when I found the rear axle pinion was loose. Swapped the axle for a spare one I had and it did nothing to stop the whine... Then I suspected the lockouts were partially engaging and swapped on a set of new lockouts with no change.
    Now that the weather has gotten colder the whine is no longer there...
