SM465 mods
Discussion in 'The Garage' started by Jeromy Gibson, Oct 8, 2004.
  1. Jeromy Gibson
    Jeromy Gibson 1/2 ton status
    Apr 17, 2003
    127
    Amarillo Texas
    Going to be replacing my shift forks in my 465, any mods that can be done easily while I am in there? would like it to shift faster and not come out of Granny when I let off the gas.
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    coming out of gear when you let off the gas? Never heard of that. I would say its a synchro problem but granny is unsynchronized. If your trans is all good on the inside you can shift it plenty fast. I used to shift my K5 one like it was a car trans. Heck all that throw just means more momentum on the shift /forums/images/graemlins/wink.gif.
  3. Jeromy Gibson
    Apr 17, 2003
    127
    Amarillo Texas
    The shift forks are pretty wore, I am hopeing that this fixes everything. I may just put my other in there and try it out. Also what is the best Hydrolic setup for these, my clutch fork slipped out of place when I had my blazer crossed up, and started hitting the pressure plate, now I get to replace everything.
  4. dyeager535
    26,978
    '85+ C/K clutch stuff is what you want for hydraulic.
  5. Jeromy Gibson
    Apr 17, 2003
    127
    Amarillo Texas
    will it work with my bellhousing? or will I need a new one?
  6. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    nope you need the bellhousing too. the bracket for the slave cylinder is make on to the bellhousing.
  7. Jeromy Gibson
    Apr 17, 2003
    127
    Amarillo Texas
  8. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    I think advanced adapters makes a bolt on bracket to use your bellhousing with a slave cylinder. /forums/images/graemlins/thinking.gif
  9. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    never been confirmed, haven't found any that expressly say they will work with a truck setup. I'd just get original equipment bellhousing and all. Much easier to replace parts afterall.
  10. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    too bad there isnt a short throw kit for the 465. id buy one.
  11. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    why would it be a 'syncro problem' in any gear?
    once the gear is engaged the syncros do nothing but float along for the ride
    the problem is as always lack of engagement, most likely due to the worn $hift fork$
  12. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    I have all the hydro conversion pieces for sale// listed in the sale forum...as well
  13. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I am useing the AA slave braket on my 454/465/205 setup /forums/images/graemlins/thumb.gif
    I am still installing the engine so don't have it in yet but the 'hold it into place' test seams like it will work well. I have an old cast bell, factory 72, that it is going on. Oh and I got the one to be used with a Toyota LandCruser slave w/GM master...Fun STuff /forums/images/graemlins/waytogo.gif /forums/images/graemlins/peace.gif
