SM465 NOISE
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mudddog91, Jun 8, 2001.
  1. mudddog91
    mudddog91 1/2 ton status
    Dec 28, 2000
    471
    north carolina
    IVE GOT AN SM465 THAT I JUST SWAPPED IN MY 74 WITH THE 205 BEHIND IT,I USED THE FACTORY SPRINGS THAT HOLD THE CLUTCH PUSHROD TO THE RELEASE FORK AND FOR SOME REASON WHEN THE TRUCK IS RUNNING IT SOUNDS LIKE THE RELEASE BEARING IS BOUNCING OFF OF THE CLUTCH FINGERS?IF I PUT SLIGHT PRESSURE ON THE RELEASE FORK IT GOES AWAY.ITS GOT NEW RELASE BEARING .WHATS THE DEAL?WONT THE RELEASE BEARING WEAR OUT SOONER WITH MORE PRESSURE APPLIED TO KEEP IT QUIT?HELP PLEASE!!!!!!!!
  2. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    I'm not exactly sure the noise you are trying to describe, but I'm thinking mine does the same thing. All 465's are noisy to some extent. All the ones I have driven make kind of a soft grinding noise at idle with the clutch out, but they still last forever. Or is yours really loud???
    '73 K5
    Chevy good...Ford bad
  3. 4x4k20
    4x4k20 1/2 ton status
    Mar 17, 2001
    1,699
    williamson ga.30292
    sounds like the front bearing is bad i have owned several trucks with the 4-spd the front bearings are bad about going out
    4x4k20
  4. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Mine makes a sound like that. In my case its the spring resonating to the vibration of the engine at idle. So I put a piece of black plastic electrical wire conduit around it. The sound stopped right away.
