SM465 NP 205 Bolts
Discussion in 'The Garage' started by ProJunkRacing, Dec 30, 2005.
  1. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    What size bolts size thread length did you all use for your sm465 adapter , and np205 i might need to go buy some more
  2. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    post your problemtoo... someone may know whats up...:doah:
  3. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    ok so my trans would not spin when mounted to adapter and tcase
    unbolted t case from adapter still not spin then unbolted trans and adapter then it spins wtf?
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    do you have a gasket between the adapter and the tranny?
    i think they are a 3/8" bolt like 1 1/4" long, its been a long time since i had one out, so im not exactly sure.
  5. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    i could not find a gasket any ideas where to get one?
  6. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
    They are two diffente lengths. The ones that go into the tcase are about .250 longer than the xmsn ones. If you need pics I can oblige.
  7. 6.2puller
    6.2puller 1/2 ton status
    Jul 8, 2004
    569
    New England
    You need to run a factory width gasket between the adaptor and tranny. They work like a shim to pre-load the bearings. No gasket = tons of load on the bearings and thats why you can't turn them by hand.
  8. GotLabs
    Jul 30, 2005
    2,795
    Transient, USA
    Any idea on thickness? I have gasket material and I know I may have the same problem.
    Heres the pic mine is the 8 bolt pattern bolt on left is to the xmsn right is tcase
  9. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    where can i get the gasket i can't find it and tranny shop said to use rtv
  10. GotLabs
    Jul 30, 2005
    2,795
    Transient, USA
    I know advance sell the whole regasket kit. Or the BS'd me. I am going to make mine out of gasket material.
  11. 6.2puller
    Jul 8, 2004
    569
    New England
  12. GotLabs
    Jul 30, 2005
    2,795
    Transient, USA
    DANG!! I have a folder with all the part number post printed out, didnt even think to look there.:bow:
  13. dodgedude99
    dodgedude99 1/2 ton status
    Jul 12, 2003
    784
    burbia of illinois
    i just made my own gasket from the old crusty piece traced onto roll gasket material. then spent 30 minutes cutting it out with an xacto knife.
    i kept the old gasket and have extra roll stuff, if you like i could trace another and mail it to you.
  14. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    link didnt work
  15. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    so these are right then?
    crap it charges me for 5 gaskets i dont need 5
    which is which gasket
  16. 6.2puller
    Jul 8, 2004
    569
    New England
    that part number should be good at your local GM dealer also so you can get one and see that it is the right side of the adaptor.
    The link wasn't really a link. The new forum software isn't allowing cut and paste (atleast not with firefox) so I use the attach link to cut and past. :D
    Saves typing.
  17. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    ahh i will call over there then used to work there :wink1:
  18. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    GM package quantities... since no dealer is going to stock it, you're probably stuck with buying 5.
  19. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    and other ideas where i can get it at?
  20. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    any ideas which gasket number is which or do i honestly need both of them?
