SM465/NP205 adaptor,need pic.
Discussion in 'The Garage' started by BobK, Apr 8, 2007.
  1. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    Does the adaptor from a SM465/NP205 combo,retain the input bearing on the NP205 or should there be a retaining collar.
    Pic's wopuld be nice.
    Thanks,Bob.
  2. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    What year set up?
    On the early pre-85, ten spline type the 205 input bearing is held in place by the adapter. The bearing has a snap ring on it that is pinched between the adapter and t-case to hold it.
    On the 85+ type there is an aluminum collar retaining the bearing.
  3. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Cool,Ya it a 77,10 spline.
  4. 454k30
    454k30 1/2 ton status GMOTM Winner
    Sep 13, 2004
    1,613
    California, MD
    yep then yours is held in by the adapter. Suprised me the first time I had my case out and the bearing would almost fall out of there.
  5. k30bb468
    k30bb468 1/2 ton status Premium Member
    Oct 2, 2004
    955
    NW Pennsylvania
    10 spline NP205 & 32 spline NP205 up to 85 , on both the input is retained by the adapter.
    86-91 32 spline NP205 the input is retained by an aluminum seal housing/ bearing retainer .
  6. 454k30
    Sep 13, 2004
    1,613
    California, MD
    just have three of those laying around do ya? Good stuff.
  7. k30bb468
    Oct 2, 2004
    955
    NW Pennsylvania
    Yea, and some other junk too :D
    Hijack over :D
  8. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Good info..didn't know there were different sized Figure 8 adaptors either...or do they just look different in this pic.?
  9. dyeager535
    26,975
    Since it looks like you've got two apart, does the T-case side on the pre '85 cases need a stock gasket to keep the adapter from bottoming out before the bolts seat fully? (like the transmission side for the 465)
    I can't recall if that side uses a thick gasket or a paper-thin one.
  10. k30bb468
    Oct 2, 2004
    955
    NW Pennsylvania
    The gaskets that came in the kit I had were the same thickness for both sides of the adapter , and yes both sides require gaskets.
  11. k30bb468
    Oct 2, 2004
    955
    NW Pennsylvania
    The adapters are the same bolt pattern on the transfercase side , but the input bearing is a different size ,the T400 32 spline input uses a bigger bearing than the SM465 10 spline . The transmission side is totally different.
    T400 32 spline pre 86 adapter
    SM465 10 spline adapter (not a real good pic ,but the only one I have right now)
    Better pic of the 10 spline adapter
  12. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Question : I was not aware that the figure eight pattern 32 spline 205's ever came behind a 465 . To the best of my knowledge the only figure eight pattern 32 splined 205's were behind TH400 applications and then in 1985 both 465 & TH400 205's started with the universal round pattern 205's with the longer splined in-put gear . What application and year did that figure eight pattern 465/205 come from ?
    Tom
  13. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    Tom, you are correct in your thoughts; the picture leaves an illusion. The drive sleeve is attached to the input, making it look like a long 32 spline input.
    Jimbo
  14. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    Yah , I saw the sleeve on the 10 spline pic . I think I read his post wrong and thought he indicated that GM offered a pre 1985 465/205 32 spline case which just ain't so . My bad , I need to read more carefully.......
    Tom
  15. k30bb468
    Oct 2, 2004
    955
    NW Pennsylvania
    You are correct, GM never made a 32 spline NP205/SM465 until 86 & it was the round pattern transfercase. The pictures were to show the difference in the adapters.
