SM465-NV4500
Discussion in 'The Garage' started by Confedneck, Nov 15, 2003.
  1. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    has anyone done an SM465 to NV4500 swap? If so, what was involved, about how long did it take you to do, and will that nv4500 bolt up to my 86 np208?? just wondering because id sure as hell like another gear in my truck without going auto or a gear-vendors style overdrive..
  2. tRustyK5
    Jul 23, 2000
    36,169
    1,366
    E-town baby!
  3. Confedneck
    Nov 1, 2002
    5,236
    rene, thanks, just sent them an email!! /forums/images/graemlins/thumb.gif
  4. cornfed
    cornfed 1/2 ton status
    Oct 15, 2001
    295
    washougal wa
    I used the stock clutch pedal and welded a round piece on to connect it to the cylinder shaft. I personally think the best part is having a hydro clutch. I used an AA bellhousing and the factory GM slave, hose, and reservoir. The shifter sits about 3" farther back if I remember right, and the top of the tranny where it comes out is a little taller also so you do have to modify the floor. Mine is bolted to a doubler setup, but you will probably have to move the crossmember back on yours too.
  5. Confedneck
    Nov 1, 2002
    5,236
    cornfed, so did you only weld that piece on because you went from mechanical to hydro? mine is hydro clutch already..and as far as shifter location goes, would it interfere with my stock bench seat? because right now reverse is kinda close, but i think 3" is gonna make it a little tight??thanks ! /forums/images/graemlins/thumb.gif
  6. cornfed
    Oct 15, 2001
    295
    washougal wa
    Yeah I welded the piece on because I used my mech. pedal. The throw is a shorter on the NV so you may be okay, if not BD sells a short shift kit for dodges, they may make em for GMs too, Im not sure though.
  7. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Yes. It bolts right on. No adapters required. (Providing your np208 is 32-spline - SM465 or TH400 application).
