sm465 or th400 And a poll!
Discussion in 'The Garage' started by Kyle Strong, Jun 6, 2006.
sm465 or th400?
  1. 465
    56.4%
  2. th400
    36.2%
  3. Just get a new t-case
    1.1%
  4. I'm nekkid (mandatory option)
    6.4%
  1. Kyle Strong
    Kyle Strong 1/2 ton status
    Sep 26, 2005
    280
    Eugene, OR
    so, I think my 203 is getting ready to take a crap on me. I've always wanted a 465, but with the body lift I hear mounting the linkage could be a problem. I could go hydro, but don't know if I have the money for it.:( I can get a 465/205 combo for around $200-$250 I think. Or my friend has a th400/205 combo his friend pulled out of a mid 80's 1 ton for FREE:saweet: He said it all works fine. It's pretty much decided I'm going with a 205. So now it comes down to the trans. It will be a dd, but I don't mind a manual, and I don't think it'll see too many highway miles, so an overdrive isn't that big of a deal (even though neither of the options come with an overdrive:doah: oh well) I could just get a new t-case, but the th400's FREE:saweet:
  2. 1-tonmudder
    1-tonmudder 1/2 ton status
    Apr 24, 2005
    3,052
    In a junkyard somewhere
    So whats to question??I never have that kind of freinds.Im always the friend that has the stuff.
    I personally like an auto,yeah I know they dont have much compression braking and you cant roll them off,but it's nice to have only two pedals to deal with when you are hanging off a mountainside.
  3. Kyle Strong
    Sep 26, 2005
    280
    Eugene, OR
    Yeah, I know that one. And I've always liked auto's, but everyone I know swears by manuals. If it makes a difference, my truck will be for trails and mud, no rocks. Unless they get in my way:haha:
  4. 1-tonmudder
    Apr 24, 2005
    3,052
    Have you ever tried to speed shift a 465.I do some mud racing from time to time and there is always some guy that is running a grannygear 4 speed,First is to low and second is to high and there is so much difference in the two by the time the RPM's drop enough to shift you have lost your momentum.A 465 will probaly be more durable than a 400 though.
  5. Kyle Strong
    Sep 26, 2005
    280
    Eugene, OR
    No I haven't, but my dad's old 67 ford had the same granny gear first. We never put it in 1st unless we were crawling up a hill! And the 465 is stronger I think, but for now I have a stock 350, so the 400 should hold up fine. Until I drop in my 427 or 454. Evne then it might.
  6. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    465 is beefy and massive reduction already. But like someone said, its nice only having 2 pedals to mess with in a predicament. Also there is alot more to do, clutching, shifting, rpms... Those 2 things is what keeps me from going 465 every time ive blown up a tranny since Febuary.
  7. Citizen Rider
    May 5, 2005
    1,415
    Plano, Texas
    Oh, and free is always better when on a budget!!
  8. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    personal preference. Personally I'd prefer a full manual reverse pattern th400 over the sm465 in a wheelin rig. If its a street rig or a tow rig, I'd prolly want the 465.
    j
  9. Kyle Strong
    Sep 26, 2005
    280
    Eugene, OR
    I know the full manual part, but what's reverse pattern? Shift pattern?
  10. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,923
    333
    Fort McMurray, Alberta
    Makes the shift patter P R N 1 2 3 instead of P R N D 2 1
    Allows you to use the column for shifting, and just makes it "right" by lowering it a step instead of bringing it "up" a gear.
    I personally switched to an SM465, and have no regrets as of yet. Mine is a DD / Tow Rig though, not an offroad vehicle. If I was to go offroad and do any sort of crawling / mudding, I'd personally want an automatic.
  11. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    well obviously Free cannot be beaten....
    however I had a turbo 400 with a b&m shiftkit..... it was nice.... but once I went to SMC465 I WILL NOT TURN BACK!! NOT EVEN FOR A FREEBIE!!!!!
    now for your delema on the linkage...
    yeah sucks that you gotta look at this.. how much body lift?
    I have the clutch rod that goes from the pedal through the floor.... you can have it.. already has a 3" extended piece (if you have a 3" bl)... just pay shipping and it is yours...
    now hydraulic is the way to go... it isnt as expensive as you think.... all said and done.... you find the donor truck in the junkyard..... usually u pull its are cheaper....
    the only thing is the bellhousing maybe hard to get from a u pull it....
    this is the problem with the mechanical..
    unfortunately no matter which manual setup you go you need a few expensive parts....
    mechanical list:
    1. pedal assembly
    2. rod through floor
    3. z-bar
    4. adjusting rod
    5. clutch fork ($25 autozone)
    6. bellhousing
    7. clutch, pressure plate, throwout bearing ($130 lifetime warr. autozone)
    8. Flywheel ($75 from most yards)
    hydro list:
    1. fill resivour with hose
    2. pedal assembly
    3. hydro master cylinder
    4. bellhousing
    5. hydro piston (mounts on bell)
    6. clutch, pressure plate, throwout bearing
    7. Flywheel
    I think that is it....
    shame... ya didnt see my for sale stuff a while ago...
    http://coloradok5.com/forums/showthread.php?t=146753
    I had everything for a manual swap... had it here for $350 but let it go for $150!!!!!
    even 2 flywheels, 2 clutches, 1 pressure plate
    you should be able to go hydro cheaper.... shouldnt be much... the yard shouldnt want more than $100 for everything... and to me that is cheap... although I bought a 1985 fullsize jimmy with hydro for $100 and stripped it :wink1:
  12. mrk5
    Apr 20, 2004
    12,332
    1,040
    Northern Colorado
    The TH400 will stand up just fine behind a 454 also. The TH400 was bolted behind quite a few GM muscle car rat motors.
    That 205 behind it would be real nice to have if you want to do a doubler.
  13. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    yeah, puts 1st and reverse nice and close together. Being able to shift between the two quickly could be the difference between rolling and not rolling. Nice thing to have... and you don't have to grow a third leg to operate the transmission either. ;)
    j
  14. RootBreaker
    Nov 29, 2001
    5,117
    173
    dont think the ujoints will like that..... :haha:
  15. mrk5
    Apr 20, 2004
    12,332
    1,040
    Northern Colorado
    I think you would just about have to have reverse pattern with full manual. Otherwise you'd be going straight into 3rd out reverse, and with full manual you'd be IN 3rd.
  16. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    400 all the way!!! For off road use......I know I know..a lot of you 465 guys dont agree, but having that third pedal and more to think about instead of just wheelin doesnt seem fun to me.... Ive always said that carbs and clutches are for racing --- auto's and fuel injection are for off road ...just my 2 cents
  17. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,229
    486
    New Hampshire
    I Looooooove :p: my SM465 :bow:! Most of you guys are intimedated by running a clutch but it is just second nature for me now and I have only been driving a stick for about 2 years now. Plus you don't need to use your brakes decending hills which can be dangerous. I love engine braking. You won't regret going to the SM465. :bow:
    If you end up going with the auto, then go with a floor shifter.
  18. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    you can get engine braking from an auto... just need lower gears.
    driving a stick is second nature to me... I learned to drive on a stick and an auto always feels a little strange. That doesn't change the fact that in a really nasty near rollover I might not be able to work all 3 pedals in rapid enough fashion. Really steep off-camber situations would be my biggest concern. All of that said, I do plan on running a manual in my toy buggy... but in that I'll have a hand throttle... and just 2 pedals. One for each foot, just like God intended!
    j
  19. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    Manuals are awesome....Nuff said.
  20. Kyle Strong
    Sep 26, 2005
    280
    Eugene, OR
    Ya, I just really don't know right now. I think I'm going to wait a while and think it over real hard. I'm leaning more towards the 400 right now, mainly becasue it'll be less work. Right now the weather's been pretty sh*tty recently, and when the weather's crappy, I have no motivation to do anything. I might feel up to a 465 swap soon. That, and I want to be lazy for a few days/weeks since my last day of high school was today! :saweet:
