Sm465 Question
Discussion in 'The Garage' started by 808CK, Mar 7, 2007.
  1. 808CK
    808CK Newbie
    Dec 1, 2006
    Hawaii
    Gonna do the swap .. i currently have the 700r4/208 setup. swapping to a 465/205 setup. Now my question is will i have to do any drive shaft mods. Im running a 6in/shackle flip 1" zero.
  2. jones
    jones 1/2 ton status
    May 17, 2004
    379
    IONIA,MI USA
    Let's see if I remember...the 700r d-shaft will bolt to a 14bff w/o a conversion joint(I know that's not the question)and...I think,mine had to be extended from 64"-67".HOWEVER...I didn't use the 700r d-shaft.I pulled one off a '78 J20,used that because it had a slip-shaft.cost for extending w/ new spicer u-joints in both ends was $152+ change out the door.I don't think there's any way you'll know until you do the swap.I forgot: No lift involved in my swap.stock height.
  3. 84 K5 4x4
    84 K5 4x4 1/2 ton status
    Nov 14, 2006
    163
    Jasper Ga
    I just did the same setup in my blazer and i had to get a differnt rear drive shaft and shorten my front. Keep in mind the tranny and tcase i got came from a truck.
  4. protechk5
    protechk5 1/2 ton status
    Sep 26, 2004
    2,015
    VA
    yeah your going to have to get a new rear drive shaft if the 205 is a fixed yoke, and your 208 is a slip yoke, and you also might have to shorten the front a few inches
  5. 808CK
    808CK Newbie
    Dec 1, 2006
    Hawaii
    Forgot to mention. The tranny and t-case came from a 79 K10 I still have the front drive shaft on the T-case. Even with the lift ill still need to shorten the front shaft? Infact the axles that are on my truck now 10b/12b came from the same truck the 79'. I had to have the U joints modded to fit my driveshaft now. My truck is a 86 K10.
