sm465 questions
Discussion in 'The Garage' started by 84gmcjimmy, Dec 19, 2004.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    What is the spline count for sm465 trannies that have a np208 bolted up behind them?
    I searched and didn't find too much...
  2. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    nevermind found it... 10 spline, right? What kind of machining would it take to convert it to 32 spline? How can I make a np203 from a th-400 bolt up?
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    sm465 with a 208 is 32 spline
    sm465 with a 205 is 10 spline up to 84-85 then that is also 32 spline
  4. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Yeah I just read that on ORD's site. What would it take to put a th-400 version np203 behind it? Possible?
  5. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    pulled from the ord site
    :thumb:
  6. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Ah, thanks TJ. So the th-400 version np203 will have 32 splines right? Then I just need to drill and tap the bolt pattern onto the sm465 case, then it's ready? Will this be very strong? I looked from where you pulled that, and it says:
    Except that method needs machining, and I don't have a shop near by that machines stuff like that.
    Method 2 I guess i'll use!
  7. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    You redrill the front face of the NP203 so it has the same pattern as the 208. The 208 adapter you have is your template ;) Strength should be no different than stock.
    The other way (using the SM465/203 adapter) is essentially the same for strength, but the adapter is not common. The main benefit is it ends up shorter overall, but comes at a price.
  8. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Ooh okay I understand now. Thanks.
  9. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    I got a 32 spline 1981 SM465 tranny with a 208 adapter. :D
  10. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    LOL it's okay, I already have one, it's in the Jimmy right now.
  11. mountainexplorer
    Nov 14, 2001
    4,903
    Never miss an opportunity to try and make a sale. Ha. :D
  12. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    I'd imagine you have a couple of those anyways... I know where to go if I end up needing one though! :)
