sm465 severe pulsate in reverse
Discussion in 'The Garage' started by rphenry250, Oct 28, 2005.
  1. rphenry250
    rphenry250 Registered Member
    Aug 25, 2002
    23
    Fayetteville, Arkansas
    hi, ive got a 1983 K5 with a SM465 and NP205 and when i put it in reverse, it shudders horribly then once in a while it wont then next time it will. I just had the clutch redone (including flywheel resurfacing). All other gears are fine, anby ideas as to what this could be?
    thanks
    RPHenry
  2. guido666
    guido666 1/2 ton status
    Feb 16, 2005
    788
    Longmont, CO
    You could be missing a (couple?) gear teeth. Other than that, it's all gear drive so there should be no way for anything to slip or move (unlike clutched systems).
    I'm no brake expert, but I know drum brakes self-adjust when you are going in reverse. Could it have something to do with that?
  3. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Most likely you have a bad motor mount or tranny mount.
  4. suburban n progress
    suburban n progress Registered Member
    Apr 15, 2005
    19
    Florida
    one time mine did that so i checked mounts crossmember and everything i could find...and turned out to be my ubolts on my rear axle were loose..tighten them way down and its like all vibrations went away AND felt smoother while going forwards..could be a similar problem..HOpe that helps :burb:
  5. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    its the way your letting the clutch out/ applying the gas, all standards do this if you are a little off... thats why it only happens only sometimes
  6. JonV
    JonV Registered Member
    Mar 17, 2003
    27
    Hesperia, CA
    Mine did that. Replaced motor mounts; fine ever since :laugh:
