SM465 Shift Lever
Discussion in 'The Garage' started by jon v, Jul 18, 2004.
  1. jon v
    jon v Registered Member
    Jul 8, 2004
    22
    Hesperia, CA, USA
    Where can I get a new Shift Lever for my SM465? It's a bit too sloppy. /forums/images/graemlins/thinking.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/whistling.gif
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    there was a post on how to fix that. IIRC a weld breaks and becomes slopy, i think you just weld it back up, but not sure exactly where.
    you could always try a junkyard.
  3. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Did you take it out and look at it yet? It's not a real complicated device, so I can't see it being bad unless the weld is broke. In that case, what he said. It's real easy to take out, so I would check it out before I went looking for another one.
    Remove the boot.
    Spray a little WD-40 around the edges of the round ball looking piece at the base of the stick.
    There's a spring under it, so just push down on the ball and turn it counter clockwise a ways and then release it and it should all just pull straight out.
    Here's a pic, the one on the right, except the spring and lower half of the ball are covered up with masking tape. [​IMG]
  4. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    I thought the sloppy feeling was normal?? every smc465 i have driven had like a ton of play when in gear /forums/images/graemlins/dunno.gif
