sm465 shifter
Discussion in 'The Garage' started by nyyef, May 5, 2004.
  1. nyyef
    nyyef 1/2 ton status
    May 16, 2000
    479
    Saudi Arabia
    is there an aftermarket shifter for the sm465 to shorten the throws and/or take up the slack?
    if not, are there any mods to improve whats already there?
    i did a search and couldnt find anything. Thanks.
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Nah, unfortunately there's nothing in the aftermarket...
  3. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    you can however make the clutch action quite a bit better with mods to the linkage... tightens up the slack...
    go here
    http://www.speeddirect.com
    and look for the linkage kits... or make one yourself
    hope this helps
    cam
  4. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    Or ya could go hydro... /forums/images/graemlins/grin.gif
  5. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Going hydro won't effect the way the shifter works at all. That's all clutch pedal.
    Alot of those shifters have a small tack weld right near the end of it that breaks and causes a bit more slop/play. Pull the shifter out of the tranny and look at the end...If the tack is broke, it'll be retty obvious. Mine was. I re tacked them with the TIG welder for a bit more strength. Tightened it up quite a bit. /forums/images/graemlins/pimp1.gif
  6. stock93
    stock93 Registered Member
    Feb 18, 2004
    68
    Huntsville, AL
    How does the shifter come out?
    John
  7. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    Yeah, I know, I was talking about going hydro instead of the heim-jointed linkage. /forums/images/graemlins/thumb.gif
  8. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    John
    Take the rubber boot off (usually held on with some screws under the carpet) and then push DOWN on the collar at the base fo the shifter (it is spring loaded) and turn counter-clockwise. The the shifter will pull straight out!
    Chris
  9. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    Make sure it's in neutral first, or it'll be a beotch to get back in.... /forums/images/graemlins/grin.gif
  10. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    go here
    hope this helps
    cam
    Cam, do you know much about these kits and if they work well? I have a 465/205 I've been dying to put in my K5 and don't have the time or money to do a hydro swap right now. I also need a new linkage in my '68, but it says "63-72: coming soon /forums/images/graemlins/doah.gif" This might be the ticket though /forums/images/graemlins/thumb.gif
  11. camiswelding
    May 25, 2003
    2,545
    Redding, CA
    I dont really know anything about these kits... I mean I havent seen one
    I built one.. couldnt stomach the 65 bucks they were asking... this week however Ive been converting to hydro... more because my 2 other later model trucks are and I really wanted to have all of them be the same,,,and the hydro feels so much smoother to me
    a couple of heim joints and round stock threaded cost about 20.00.... I used their pic and my stock linkage measurements...with adjustability
    It really tightened up the slop but I didnt notice any other improvement...ie off camber performance....Im running a centerforce stage 2 clutch which is so stiff anyway noting a difference is pretty subjective....its real stiff or very stiff... was the mod worth it.. sure ..its one of the only games in town...one only has to look at how basic(read minimal engineering and cost) the manual linkage is... and mine was sloppy after a lifetime of shifts... I tried originally putting in bronze bushings to take all the slop out of the stock linkage... dont bother wasting your time it didnt make any difference other than it was tighter... not smoother..
    Ill check the tranny mod that was discussed when I pull my shifter next week... tranny is out for a short shaft conversion...and doubler as soon as I can afford it...
    cam
  12. stock93
    Feb 18, 2004
    68
    Huntsville, AL
    Thanks guys. My welds were busted on mine. I bet it will shift a bit better once welded up. Would it hurt anything for me to weld it all the way around?
    John
  13. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I welded mine all the way around the end, plus the little pin that goes thru it. Really tightened it up.
  14. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    ya' just use a bfscrewdriver, to move it back to neutral, takes 5 seconds. /forums/images/graemlins/waytogo.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/grind.gif
