*sm465 splines?** what th350 will bolt to my np205 -RE:correct output shaft
Discussion in 'The Garage' started by uglychevyZZ4, Apr 20, 2003.
  1. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    what is the casting #'s for the TH350 that will bolt to my np205? i was gonna buy the one from poohbair but it is the wrong spline shaft.... anyone know?
  2. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Re: Tranny cast #\'s? what th350 will bolt to my np205 -RE:correct output shaft
    All TH350's are 27 spline. The difference is between 2WD or 4WD. The 4WD stick out length is 7/8" beyond the end of the case.
  3. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    now im confused, i was gonna get poohbairs and he said if i had a 205 now, the splines are wrong????
  4. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    ok, now i get it, so all 350's are 27 spline but there are 2 different versions of my 205?
    so what can be done? change th350 output or 205 input??
  5. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    I thought you should just be able to swap in a different adapte...But what do I know.... /forums/images/graemlins/eek.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/1zhelp.gif
  6. SCOTTS_4X
    SCOTTS_4X 1/2 ton status
    Mar 22, 2002
    129
    Modesto CA
    the short "4wd" output shaft 350 will have no tailshaft housing, just a square-ish 4bolt pattern with the shaft sticking out about 7/8" like stated above. the "2wd" long shaft will either have a long tailshaft housing sticking off the back and a seal for a slipyoke to slide on the splines (looks pretty much like the back of a 208) or it will have the housing removed and you'll see ALOT more than 7/8" of shaft, more like 4-5 inches.
    -Scott
  7. chevyfumes
    Feb 24, 2000
    38,584
    266
    I understand that, I think...LOL I thought he would just need a different adapter plate for his 205 to bolt up to a 350 4X4 tranny instead of a 400... /forums/images/graemlins/thumb.gif
  8. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    He would need the TH350/NP205 adapter as well as the drive sleeve and also a 27 spline input NP205. The TH400 uses a 32 spline output shaft. He would need to convert the TH400 input shaft in the NP205 to a 27 spline input for that case to work.
  9. SCOTTS_4X
    Mar 22, 2002
    129
    Modesto CA
    yeah, as scott said, you will need to change the input shaft of the t-case if it originally came off of a 400. if it cam'e off of a 400 it will have a female input, I.E. the shaft that is sticking out of the tranny will mate inside the input of the t-case. if it's off of a 350 it will have a male input shaft, just like th output shaft of the tranny, in which case they use a hollow splined "coupler" that goes over both shafts. did that make sense?
    -Scott
  10. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    This is what I (think I) know...
    TH350 205/203 use the same 27 spline output shaft and different adapters. Short adapter with female input on the 203, longer adapter with male input on a 205 (use a coupler tube). 208 on TH350 uses a longer output.
    TH400 uses a 32 spline femal input on the TH400 and no coupler. 203/205/208 are all different length outputs and there are 2 different 205 adapters (round and "8") but I think they use the same output.
  11. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    was never a 400. it has been 465 /205 and i hate having a stick and want to get atx /forums/images/graemlins/1zhelp.gif
  12. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    I've got a th350 and a 205... my tranny has the 7/8" stickout that was mentioned by everybody else, but my setup uses no drive sleeve, the trannys shaft sticks right into the transfercase without one. I didn't put this combo in the truck... so I have no idea where it came from. The output shaft is the same as the other 4wd Th350 that I have, so that isn't any different.
  13. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    let me add to the confusion /forums/images/graemlins/rotfl.gif
    4x4high is right on from my experience
    i will only add that please keep in mind that the np205 32 spline that fits the turbo 400 32spline naturally has a larger diameter in the case to accomadate the larger diameter shft so
    so ya cant use the 32 spline t case on a turbo 350 tranny with out MAJOR mods
    and to the guy that says he has no drive sleeve
    do you know what 1 is ??? i think not as every 350-205 that i have seen has a drive sleeve weather mounted in the adapter perminentially or "floating" between the seals
    well thats it from here and if ya still looking for a 205 with adapter and drive sleeve and shifter pm me as i have 1 i would sell with guarantee
    hope it helps
    Randy /forums/images/graemlins/usaflag.gif
  14. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    so how many splines is my 465?
  15. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    If its an early SM465 then it will be a 10 spline, if it is a later round bolt pattern then from what I have heard it could be a 32 spline.
  16. JDNobodi
    JDNobodi 1/2 ton status Premium Member
    Oct 9, 2002
    3,002
    194
    Santa Maria, CA
    Calclips, you must have an have an early TH350/NP205 tranfercase(pre 73). The drivesleeve is supported by a big bearing in the adapter.
  17. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    I think the "stick" has a spline count of 10. You will still need the adaptor, from the stick to the 205. /forums/images/graemlins/eek.gif
  18. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    **** It Man just get a 350/203 and then save your pennies for a doubler.
  19. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    ya, im thinkin bout it, but dunno yet. i have access with that setup from poohbair but he wants my np205 in trade, not sure if i can let that go /forums/images/graemlins/rotfl.gif
  20. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    If you are not totally confused yet...
    Your SM-465/NP-205 has a 10 spline output/input and coupler. To use it behind a TH350 you would have to get the TH350 adapter, 27 spline drivesleeve and 27 spline input gear for the NP205. The t-case input bearing is the same size on both the 10 spline and 27 spline.
