SM465 stuck in gear (3rd)
Discussion in 'The Garage' started by lamberthkp, Apr 18, 2006.
  1. lamberthkp
    lamberthkp SITFU Premium Member
    Jan 17, 2005
    1,468
    16
    West TN
    well my tranny got stuck in 3rd gear yesterday,i shifted pretty fast from 1st to 2nd, L,1,2,3. and it stuck and wont come out. what do yall think happend?
    maybe i jumped the forks or something like that :dunno:
  2. mdm365
    mdm365 1/2 ton status
    Jul 2, 2001
    536
    mineral wells wv
    I had the same thing happen to mine when I was out wheeling.I played with it got it unstuck worked about three days and got stuck with no getting it unstuck.I pulled out the tranny and did a rebild found the coupler and mainshaft worn real bad,The reason it got stuck,well it was some detent balls and spring in the shift housing.The spring broke and got stuck in the shift rodsPull the carpet and tranny tunnel and then the shifter make suer its half way in reverse pull the shifter housing .could be an easy fix,that is if you can get the parts arond here it was kind of hard but I did find them. Mike
  3. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
    Ive seen synchronizers cause that also.
  4. lamberthkp
    Jan 17, 2005
    1,468
    16
    West TN
    i'll try that, well i orderd a rebuild kit last week but did not think i would be having to put it in so soon. its still on the side of the road im gunna go out and mess around with it here in a bit hopefully if im lucky i can get it home but if not looks like i will have to have it towed off base.
  5. lamberthkp
    Jan 17, 2005
    1,468
    16
    West TN
    ya iv had to hold it in gear in 3rd since i put it in or it will pop out. but that is the 1st time it stuck and it stuck good. im going to take the PTO cover off and see whats going on. you dont know anyone to tow me off of base for cheap do ya $75 is as low as i have found so far in j'ville. oh ya the truck wont move either its in 3rd but like it aint in 3rd like Nuetral or something
  6. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,927
    343
    Fort McMurray, Alberta
    Can you put the t-case in neutral and flat tow it?
    BTW, pulling your PTO cover isn't going to show you anything useful, your only bet is to unjam the shifter somehow, and pop the top off.
    Most popping out of 3rd problems are shift fork related, not syncro as is the most popular suspect for some reason. Once you get the tranny apart, you'll see what I mean.
    All the syncro does, as it's name suggests is syncronize the speed of the shift collar with the gear on the mainshaft. It does this by putting a soft friction material between the gear and the mainshaft, until they are the same speed, and allows you to pop the gear in, as if the transmission wasn't moving. When guys powershift / double shift, they are just manually matching the speed of the shift collar and the gear by revving the engine up, then the gear dumps straight in as if it was syncronized.
    The syncros are made of a far softer material than the gears are, and about all that the syncros can do is wear out, and not spin up the gear you want, causing the shift collar to grind against the splines on the gear.
    Another thing that some people claim causes 3rd gear popouts is a snap ring on the countershaft (bottom gears you see when you open a PTO cover) that weakens over time and allows the gear to shift slightly forwards. But, I personally don't see how, as it wouldn't make much difference if the bottom gear is walking around a touch. It won't make the top one that has the shift collar slid onto it pop the shift collar off. I put the little sleeve that they sell aftermarket on not to prevent gear popouts, but to prevent a pretty catastrophic failure if that snap ring were to actually break, and allow the gear to slide forwards on the mainshaft, lol
    However, if your shift forks are worn out (they have a plastic coating on them from the factory that wears off), or if you've got a lot of slop in the shifter then, its gonna cause the shift collar to not engage all the way onto the gear, allowing it to slide off without much effort at all.
  7. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
    ive had it happen before you really dont need any tools cept the big pliers to get the stick handle out of the trans and put the lever blocks in neutral position again and put the stick back in, make sure the pins are all the way through and everything
    when it happened to me i put pins back where they were supposed to be and everything and it never happened again
    make sure end of the stick isnt loose wobbly
    if so then have it welded or get another handle
    what happened is the end of the stick popped out of place in the shift blocks in there
    thats all
    it happens,
    this stuff is old, some wear, etc.
    very minor
    easy quick fix too
    good luck
  8. lamberthkp
    Jan 17, 2005
    1,468
    16
    West TN
    allright just went back out before i called someone to tow it. and i finally got it to come out of gear and drove it around base and seems to shift just fine but i reckin i will go ahead and rebuild it this month or next i have my buddys truck to drive till middle of next month . :D :D
  9. lamberthkp
    Jan 17, 2005
    1,468
    16
    West TN
    THANKS for yalls help :D
  10. Russell
    Jun 23, 2000
    7,927
    343
    Glad to hear you got her movin again :)
    Don't put off rebuilding it too long if you've got a kit, it only takes about a weekend, a brass drift, a big hammer, chisel, snap ring pliers, bearing puller and a torch to rebuild. Don't need a fancy press. I don't even have a brass drift, I used about 8 feet of 2x4s cut into smaller peices, then pounded on until they split apart, LOL
  11. lamberthkp
    Jan 17, 2005
    1,468
    16
    West TN
    anyone have a big picture of a rebuild on one . found the breakdown online but it is so small i cant really tell what all goes on.
  12. Russell
    Jun 23, 2000
    7,927
    343
    I had a good pic, but I have no idea where it is now...
    Search google, I found one or two rebuild tutorials that had step by step instructions with good pictures.
