SM465 stuck in gear, shift forks, and WTB a drain plug?
Discussion in 'The Garage' started by steelsoldiers, Mar 27, 2004.
  1. steelsoldiers
    steelsoldiers 1/2 ton status
    Oct 17, 2002
    365
    Charleston, West Virginia
    I am working on that project SM465 and I noticed that the drain plug is missing. Any body know where you can get one? Part number?
    Also with the shift cover on or off, I can't seem to shift in between any gears but first and second. The shift rails look fine and they are nice and free, but it seems jammed up. Do I need to take the whole cover apart?
    One last thing, the plastic coating is coming off of the shift forks. Can they be recoated with something or should I just scrape the loose stuff off and leave it alone?
    /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the drain plug looks like a pipe fitting that you can get at any hardware store. not sure on the size though
    make sure the top cover is in neutral and the tranny, its got to be half way into reverse to get the tover back on
    i think you can get those at the dealer. i would replace them, there cheap
  3. steelsoldiers
    Oct 17, 2002
    365
    Well, the problem is even with the cover off, the shifter only wants to go 1-2. It won't go neutral or 3, 4, or R. Strange /forums/images/graemlins/thinking.gif
  4. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    pull the shifter off and see if all the notches are lined up
  5. steelsoldiers
    Oct 17, 2002
    365
    Everything looks fine internally. The forks are straight and line up right. It just won't shift. I wonder if something is bent in the cover. I can't get the shifter to do anything with the cover off except 1-2. When I put it in the neutral position it won't go to the right for 3, 4, or R. Any other thoughts? Does anyone have some photos of their SM465 that I could use for comparison? /forums/images/graemlins/1zhelp.gif Thanks.
    Chris
