sm465 to 454 question
Discussion in 'The Garage' started by littlejimmythatcould, Mar 22, 2006.
  1. littlejimmythatcould
    littlejimmythatcould 1/2 ton status
    Feb 6, 2006
    797
    Clovis, NM
    Will a sm465 transmission removed from a 1976 chevy 3/4 ton truck originally equiped with a 350 small block bolt up to a 454 big block? The reason I'm asking is that I don't want to sell my buddy a transmission that he can't use. Thanks for any and all responses.:bow:
  2. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    Yes it will bolt up and work fine however he will need a flywheel specifically for a 454. The 350 flywheel will not work.
  3. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    In short.....YES. Chevys pretty much used the same bellhousing bolt pattern for all SBCs and BBC's. Some of the later stuff is different.
    Your buddy will need a 454 specific flywheel instead of the 350 version since the 454 is externally balanced.:D
  4. littlejimmythatcould
    Feb 6, 2006
    797
    Clovis, NM
