sm465 to 700r4
Discussion in 'The Garage' started by gravdigr, Jan 27, 2005.
  1. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    My dd is a sm465/np208 combo. Can I swap in a 700r4 in place of the 465? Will the tcase work with the tranny or will I need a 208 that came with a 700r4?
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    You need a 208 from a 4 speed or th400 truck , or you need to get a 32 spline input shaft and use your own 208 :k5: :k5:
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    you may have to redrill where the crossmember is. you will need the np208 from a 700r4 or th350 and the adapter from a 700r4. you will also need to get a lockup setup, wether it be factory, aftermarket or internal. if you don't you will burn the tranny up.
    the nice thing about doing this on the newer trucks, is that the driveshafts are the same for both setups.
  4. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    766
    Granbury, TX
    your current 208 has a 32 spline input, you will need one with a 27 spline input to mate to a 700r4... from what i understand, you can just change the input on the 208, will require a full tear down, but its easier (and cheaper) than changing the 700r4 output to 32 spline
  5. gravdigr
    Apr 15, 2003
    1,129
    Tyrone, PA
    OK, it seems I may be better off just getting a 700r4/208 combo and just swap the whole thing. Will I need a different length driveshaft or will they be the same? This is on an 86 K5.
    EDIT: nm, I think big83 answered that question for me. Thanks for the info.
  6. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Find someone who wants to swap the other way and trade parts with them. Seems like I see plenty of people wanting to go auto to manual. Or maybe just trade trucks with them. :grin: :grin: It would be a lot less work.
  7. gravdigr
    Apr 15, 2003
    1,129
    Tyrone, PA
    I want the hydraulic clutch and bellhousing for my trail rig. It won't be too hard for me to find a 700r4/208 already mated together out here.
  8. k5blazin
    k5blazin 1/2 ton status
    Dec 19, 2004
    262
    Elizabethtown, PA
    i have a 700/208 combo in my parts blazer if you are interested. the tranny is blown though.
  9. Storm Trooper
    Nov 24, 2000
    4,640
    I'm think of going auto on of these days but when I do, I'll go TH400 and a doubler.
