sm465 tranny, hydraulic or manual clutch ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ambritmann, May 21, 2002.
  1. ambritmann
    ambritmann Registered Member
    May 20, 2002
    23
    North Carolina, USA.
    I have a 79' 465 tranny to go into my 82' K5 Diesel Blazer, is it possible to convert the clutch mechanism to the hydraulic set up, is it worth doing ?
  2. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    yes it can be done, you can make/fab your own bracket for the slave clutch and same the mo/time looking for a bellhousing with it built on. if you buy the slave/master cyl + hose new, you're looking to spend around $250.
    is it worth it??? depends if you'll be flexing much. then so, mechanical linkage has been around for ages. if you run into a good deal, i'd say go for it.
    ARQ.
  3. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    I've heard varrying opinions on this subject, but from the "big guys" around here, they say hydro is the ONLY way to go!
    BTW:
    hose: $26
    master: <$80 (gmpartsdirect.com) DONT USE AFTERMARKET! The adjustable rod sucks! Makes for too many variables...
    slave: <$60 (any parts store)
    Bellhousing: Get to a local yard and start hunting... bet you can land one for less than $50 IF you can find it... /forums/images/icons/wink.gif
    GRAND TOTAL - $216 - and that is being generous! I would say that for that cost, the hydro is well worth the $$$ for its ease of use on the trail! /forums/images/icons/smile.gif
    But I'll let you know for sure once I get my shafts made up and get mine back on the trail... I just installed the hydro 465/205 combo last weekend! /forums/images/icons/wink.gif
    -Dan
  4. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    DAMN!!! Where do you SHOP!
    I WISH I could find a Hydro bell for $50.00!!!! The average PRICE I found for JUST the Hydro Bell was $150.00!
    The MANUAL BH was $50-$75!
    If you get the Hydro Pedals, the 2 braces on the Hydro pedals are offset just right to go through the firewall and double as the mounts for the Hydro Master cylinder.
    I JUST INSTALLED this last weekend. I still have the auto, so it is not hooked up yet.
    Apparently, due to the angles involved the master actually sits a little lower than the pedal assemblies.
    I JUST finished my link below!
  5. TopOff
    Jan 16, 2002
    1,760
    Folsom, ca
    Check my link below.
    Converting to Hydro, I suspect, will be the hardest part. I thought I would have to fab some brackets for the Master. However, as stated in the previous post, the Hydro Pedals have a built in brace, which support the Master cylinder!
    I will get more pics of hte master on my firewall, and through the cab. I thought they were there. Ohwell hopefully tonight.
  6. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    I'd say it is worth it. My Z-bar has taken to popping off the bellhousing ball lately and it is really aggravating!
  7. TopOff
    Jan 16, 2002
    1,760
    Folsom, ca
    I am sure it's worth it... I just wonder where I can find the parts for less!
  8. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    the bell is less then that NEW from GM IIRC
  9. dyeager535
    26,982
    191
    I pay $25/bellhousing at the local yard, but they apparently have stopped pulling them when they scrap vehicles. : ( Not to brag or anything, just that people need to shop around and compare. Granted, used hyde. bellhousings are hard to find.
  10. TopOff
    Jan 16, 2002
    1,760
    Folsom, ca
    OK, where is GMIIRC?
    Phone number?
    website?
    TIA
    TO
  11. dyeager535
    26,982
    191
    lol
    "GMIIRC"= "GM If I Remember Correctly"
