SM465 vNP205 ?'s
Discussion in 'OffRoad Design' started by californiak5, Mar 8, 2001.
  1. californiak5
    californiak5 1/2 ton status
    Oct 25, 2000
    820
    Oceanside, Ca. 92056
    SM465 vNP205 ?\'s
    Hey Stephen,
    I have a SM465 with the adapter plate and the NP205 mated to it sitting at my house. My ? is can I rebuild the 205 and make it into a 400 version? If I can, what will I need to do this? Thanks.
    See Ya,
    Keith
    [​IMG] Born to Drive My K5 [​IMG]
  2. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Re: SM465 vNP205 ?\'s
    You need the input gear and bearing, and you need to have the case machined for the larger diameter input bearing. You will also need the adapter to mate to the TH400. Adapter, gear and bearing are available new for $400 and change.
    Tim
    70 Blazer CST 4X4 350 SM465 NP205
    87 Burb 4X4 350
    01 GMC 2500HD 4X4 Duramax/Allison
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    YUP, input gear, input bearing, bore case to fit bigger bearing. I think there are some details on this in some back posts in this forum.
    Cost is about $300 if you send the case to us to bore out for you. Input and bearing are $170, and the Case bore is $100. We also throw a 205 gasket kit in with the bore job.
    Making the world better, one truck at a time.
    SW-ORD
