SM465 vs. 700-R4
Discussion in 'The Garage' started by PsychoticDeadGuy, Dec 1, 2005.
  1. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    Can someone give me a breakdown on the gear ratios and most importantly the length of the tranny. I will remove the 700 and put in a 465 and both have 208 t-cases. so is the 465 shorter? and if so how much?
  2. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    465
    6.55, 3.58, 1.70, 1.00
    700r4
    3.06, 1.63, 1.00, .70
    Dont know about lengths though, I pretty sure that the 700 is longer.
  3. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    I'm interested too Psycho, I have the same set-up except I already swapped in TH350 out 700R4, used the AdvAdapter ~4".
  4. 82dieselburb
    82dieselburb 1/2 ton status
    Jan 6, 2004
    105
    central Florida
    I'm in the process of swaping out my 700r4-208 in my suburban for a 465-208.
    My 700-208 is the same length as the 465-208.
    The 465 is a shorter transmission but the 465-208 adapter is longer than the 700-208 adapter.
  5. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Does the 465-208 adap bolt-up in front, rear and bottom for crossmember mount?
  6. PsychoticDeadGuy
    Jan 8, 2005
    753
    is the adapter only needed with a 465 if it didnt come stock with a 208? if i get a 465 that came with a 208 from the factory will it be the same length or shorter?
  7. 82dieselburb
    Jan 6, 2004
    105
    central Florida
    The 465 trans is about 5" shorter than the 700.The factory 465 -208 adapter is about 8" long.
    The 700-208 adapter in about 3" long,so when you combind the trans with the adapter they are both about 27 " long.
    I just installed the 465 trans yesterday and I can take a picture showing how it mounts up if you want.
  8. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    When I yanked my 700R4/241 out and layed it next to my 465/208 they were within about an inch of each other as far as length. I ended up using a 465/205 that I had from another truck and that combo is about 6" shorter in length. My driveshaft is extremely short and I'm thinking of ways to get my engine and trans back or move my front axle forward since I keep busting front driveshafts when the suspension droops. I need a longer shaft... :D
  9. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    I think both Psycho could go for a pic, if its not a hassle.:D
  10. PsychoticDeadGuy
    Jan 8, 2005
    753
    ya, pics would be great. could you email them to psychoticdeadguy@hardcore4x4.com
