sm465 what gears?
Discussion in 'The Garage' started by nicotine, Feb 7, 2004.
  1. nicotine
    nicotine 1/2 ton status
    Jan 11, 2004
    116
    okay i have a sm465 tranny and i am currently running 33's and will be steping up to 35 soon what would be a good difrential gear ratio with this setup? i currently have 3.08 they are tall but i could imagine running 4.11 with this setup and how much and how quickly the engine would be winding out even on highway driving. /forums/images/graemlins/yikes.gif
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I had 33's and 4.10's with 350/SM465. Was cruising at 65mph doing 3000rpm. OD would have been nice. Also have to factor in a 1-2 hour minimum highway drive to get to most of the wheelin' spots around here. It was plenty of gearing even with the truck weighing a hefty 7700lbs.
    I'd stick with 4.10 even with 35's. 38/39's will warrant more gearing, but at that point I'd rather add an extra t-case than re-gear two perfectly good axles. /forums/images/graemlins/thinking.gif
  3. tRustyK5
    Jul 23, 2000
    36,180
    1,387
    E-town baby!
    I ran 35's and 3.73's with my SM465. Then 36's with the same gears and it was fine...and relatively sane on the freeway.
    Recently went to 4.56's and 39.5's (and diesel) and I could use an overdrive.
    Rene
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I'm perfectly happy with my 4.10s and 38.5s, although 4.56 or 4.88 would be more desirable, I havne't yet put out the coin to re-gear yet.
  5. monsterjim
    monsterjim 1/2 ton status
    Feb 5, 2004
    151
    north Texas
    4:10 sounds good, I went from 3:08 to 4:88 when I put the corp 14 and 3/4 ton 10 bolt in. 4th gear at 65 is 3450rpm. Thats with 36" tires. Luckily I trailer it if I have to go to far.
  6. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    well i have 33s behind my sm465 and 3.40 gears and i can peg the speedo at about 3k rpms... so if i was going with 35s i wouldnt go any lower than 3.73s in MY truck, but then im not afraid to use LO and LOW offroad..
  7. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    Rene
    thats why i want a diesel. the low end grunt to push 42's and 4.10's with the RPM at 65 would be in the nice zone for the diesel.
    im not going to re gear my stuff for a while, and the low in the 465 will be able to push through everything at the stop light. with the doubler and the 465 with 4.10's ill have no problem on the trail.
    Grant
  8. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    MPH x Gear Ratio devided by Tire Dia. x 336 =RPMs.If you have OD do RPMs x OD ratio.Hope it helps. /forums/images/graemlins/thumb.gif
  9. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Like mentioned. 4.10's or 3.73s with a 465 and 35's. A buddy of mine had a th350 with 4.56's and 35's and he would turn 3000rpm on the freeway at 65. He got 7mpg on the highway because of it.
    Harley
