sm465...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TXsizeK5, Oct 23, 2001.
  1. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    When im in gear there is some play in my shifter.. ittl vibrate or bounce around and its worse off road... is this normal? Is there anyhting I can change to help this such as bushings, etc?
    Alrite, thanks.
    6in 87' K5 w/ 35" BFG muds.
    305/Sm465/ NP208
    Kn, 4.56's.
    next... off with the cat's and a single inlet dual outlet flowmaster with 4" tips =D
  2. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    TTT
    305/Sm465/ NP208
    Kn, 4.56's.
  3. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Ive never had a 465, but other manuals I ve driven have done this. Its normal to an extent, but if its really bad try replacing the mount.
    <a target="_blank" href=http://www.geocities.com/outlaw613/K5.html>http://www.geocities.com/outlaw613/K5.html</a>
  4. dyeager535
    26,979
    You're talking just the shifter handle itself? Like when its in gear, (not running) you can still move it around a bunch?
    All the ones I've driven (SM465) are like this, but I noticed on both shifter handles I've had out, the factory weld is broken. (also has a roll pin, wonder if GM put it there because they knew the weld would break..but would be "tight" until you got off the lot)
    Not sure if welding the piece back together would fix it, but my guess would be that you would solve at least 50% of the "slop" the factory shifter has. Take your shifter off and take a look at the tranny end of it. 10 to 1, the welds busted.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  5. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Mine has the same slop. It never pops out or creates any issues so I just thought it was how it is....??
    <a target="_blank" href=http://www.geocities.com/baja/5099>www.geocities.com/baja/5099</a>
  6. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    Even when it is running... it will shake aorund by itself... i mean it doenst come out of gear or anyhting... just thought it mite be somehting to be concerned about
    305/Sm465/ NP208
    Kn, 4.56's.
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Nothing to worry about. 465's were put into trucks back in the days that a truck was a truck. Once the soccer moms got interested in driving trucks, they had to be more civilized. [​IMG]
  8. dyeager535
    26,979
    Yep, mine does the same thing. The shifter handle is so "loose" there is no way it is going to take the tranny out of gear lol. I really want to try welding it up though, and seeing how that works out.
    Dorian
