SM465
Discussion in 'The Garage' started by Swanson52, Jun 6, 2002.
  1. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    Mine pops out of 3rd gear. All others are fine, but it just won't stay in third. Any ideas or fixes?
  2. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    I hear it could be the "sliders" not sure what these are...
    Or the springs for the stick itself.
    Apparently these springs are REALLY hard to get. My friend spent a month trying to get some. He found, except I don't know where off-hand.
    Can anyone else confirm or deny this?
    TO
  3. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    Most likely it is the pocket bearing is a little worn. Common proublem for the sm465.
  4. not4show
    not4show 1/2 ton status
    Apr 24, 2001
    280
    Alabama
    Yeap, because mine does it to sometimes.
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I think that is from the strange nylon that chev put on the shift forks wearing off and not allowing you to get full engagment of 3rd gear. just a theory
  6. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    Is the remedy a complete overhaul?
  7. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    if you pull the tranny, and then remove the top cover, you can see everything shifting related.
    if the syncros are worn then, yes a rebuild is an idea.
    if the bearings are worn you have to rebuild it.
    there is a trick to the cover removal that you have to know.
    it HAS to be half into reverse to pull or install top cover.
  8. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    if you are thinking of pulling it you have to read KRAZIE87K5's great saga.
    he pulled an auto, then he swapped mainshafts in his 465, and then coverted a 73? to hydraulic clutch.
    <a target="_blank" href=http://community.webshots.com/user/dan_dycus>photo'd tons of it for us</a> good shots of 465 guts.
    <a target="_blank" href=http://coloradok5.com/forums/showflat.php?Cat=&amp;Board=blazer4x4&amp;Number=381736&amp;page=&amp;view=&amp;sb=&amp;o=&amp;vc=1>taking cover off, a d.dycus production</a>
    if you cant learn from his threads you are dead,
    http://coloradok5.com/forums/showflat.php?Cat=&amp;Board=blazer4x4&amp;Number=384311&amp;page=&amp;view=&amp;sb=&amp;o=&amp;vc=1
  9. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    Thank ya, thank ya very much. At least I am too lazy to look stuff up for myself. /forums/images/icons/wink.gif
