sm465
Discussion in 'The Garage' started by mdm365, May 21, 2003.
  1. mdm365
    mdm365 1/2 ton status
    Jul 2, 2001
    536
    mineral wells wv
    I have a few ?s did a search for rebuilding a sm465 came up short has anyone done it and how bad is it to do?I had pulled my 205 to replace the seal inbetween the trans and the case and found the splines on the trans were shot /forums/images/graemlins/mad.gifand also the drive sleve is gone on the trans side.also who can I get the hard parts from?I will have to replace the main shaft and the drive sleeve for sure. /forums/images/graemlins/angryfire.gifThanks mike
  2. dyeager535
    26,979
    Drive sleeve is available from GM for around $30, the rest of the stuff, you'll just have to do a search. 465 rebuild kits can be found. One thing I've been told though, is that you need to tear it down to find out what you need to replace, as all the kits aren't 100%. The sintered iron bushings(?) are one item that can/do wear out, yet won't come with all rebuild kits.
  3. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Synchros are also sold separately from the rebuild kits. Small parts is a separate kit from the bearing/seal kit.
  4. madmike
    madmike 1/2 ton status
    Jan 23, 2002
    496
    ohio
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    when you reassemble it next time give the adapter and shafts a good shot of grease.
    dunno if it will save them but that is my theory on it.
    real interested in 'where' and 'how much' when you get mainshafts
  6. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Last year I bought a new PTO and hyd pump for my dump truck. One of the instructions was to pack the splines with grease and to repack them each year.
  7. fbzack
    fbzack Registered Member
    Jul 23, 2002
    15
    marin , ca
