Small amount of smoke when start?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by EDGE, Sep 10, 2000.
  1. EDGE
    EDGE Registered Member
    Aug 12, 2000
    42
    virginia beach , va
    Does this mean that I need a valve job?Also,I have a small leak around both valve covers.Is this an easy fix?When I do fix those leaks is there anything that I should also do at that time.
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    First of all, when you bought your K5, you joined the "Puff 'O Blue" club. Your valve seals are allowing small ammounts of oil to drip through into the cylinders, and it gets burned off when you first start your vehicle. You can fix the problem by replacing the valve seals, but I wouldn't worry too much about it unless you start to have a problem with spark plug fouling.....
    It also sounds like your valve cover gaskets need to be replaced. It's an easy, cheap fix.
  3. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    A small amount of smoke? It's just getting broken in!
    creepin' and crawlin'
    Jim
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I dont call my K5 old blue for no reason. It just the valve seals no big deal. Someday I will get around to putting in new ones.
  5. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
    You would think Chevy would have taken care of this problem decades ago! I had an 88 GMC shortbox (low-rider, please don't laugh) and with 35,000 miles on it it would puff a little blue on start up. It upset me so much to see a new (at the time) truck puffing blue on start-up that I paid $200.00 to have it fixed. Its just the valve seals, an embarassing problem but not critical by any means.
    My 81 Jimmy does it now too ( not for very much longer though) [​IMG]
    Rene
  6. White Knight
    White Knight 1/2 ton status
    889
    Ft Worth,Texas
    Look on the bright side as long as you see that lit'l blue puff....you know that the ole girl is working!!!!!
    White Knight
