Small base circle cams, Where can you find them?
Discussion in 'The Garage' started by bigburban383, Jan 10, 2004.
  1. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    I need a small base circle camshaft for my stroker, where do I find one?
  2. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    All the manufacturers make them....Just call around.
  3. 85m1009
    85m1009 1/2 ton status
    Jul 11, 2000
    718
    Missouri
    I am running an Isky cam in mine.
  4. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    for the 383?? cant you just clearance the rods a bit? Or are you using 6" rods?
  5. bigburban383
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    I kinda screwed up and balanced that stuff first so I dont want to spend $200 again because I ground the rods.
  6. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    You can still grind the rods and it isn't going to make any difference that you would ever know. Just make sure to do ALL the rods and also the same amount. If you had to trim material from the piston area then it could make a difference but not since the grinding is very near the crankshaft end.
  7. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    Agreed....
