small block 350 spark plug wires
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by newbe73, Mar 28, 2002.
  1. newbe73
    newbe73 Registered Member
    Mar 14, 2002
    58
    SD
    can you give me a diagram or tell where the spark plug wires go from the distributor to the spark plugs. for a 350 small block on my 73 chevy blazer or tell me the firing order.
    i am waiting right now for a response because i am working on it right now. COME ON GUYS I REALY NEED YOUR HELP NOW SO DO NOT JUST PASS MY QUESTION TELL ME!
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    The firing order is :
    1-8-4-3-6-5-7-2.
    I usually put the #1 wire on the 5 o'clock position on the distributor cap.
  3. newbe73
    Mar 14, 2002
    58
    SD
    YA BUT HOW DO I APPLY THAT TO GET THE ORTER ON RIGHT ON THEE CAP
  4. newbe73
    Mar 14, 2002
    58
    SD
    YA BUT HOW DO I APPLY THAT TO GET THE ORDER
    ON THE DISTRIBTOR CAP RIGHT
  5. Can Can
    15,552
    136
    Put the #1 wire on the 5 o'clock tab on the distributor cap. Now follow the firing order above and go clockwise around the cap with the next wire and so on......
    Does that make sense?
  6. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Your cylinder order is Driver side bank 1-3-5-7, passenger bank is 2-4-6-8. 1&2 are the closest to the radiator. At least this is the order if I remember right cylinder wise. Then I think that you just put the wires from the firing order above on clockwise from the 5 o'clock position.
  7. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Assuming that piston #1 is at TDC.
  8. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Why would that matter?
  9. newbe73
    Mar 14, 2002
    58
    SD
    ok i sort of get it but it keeps misfiring but i know i am doing someting wrong here. here is kinda a diagram of want a am doing tell me what i am doing wrong
    this is the cylinders the way i # ordered them
    8 7
    6 5
    4 3
    2 1
    then this it the way i put them on the distributor
    __________6___5_____
    _______3_________7_____
    _______4_________2_____
    __________8___ 1_____
    tell me what i am doing wrong plz
  10. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    Your diagram is right, and the order of the cylinders you have listed is right. If you have it wired the way you have it shown then that is not the problem.
  11. Russell Keys
    Russell Keys 1/2 ton status
    Mar 16, 2000
    253
    Huntsville, TX
    I'ts been a while but if it still has points ignition isn't #1 one off from Hei? If so you will need to advance(?) the wires one space. I might be wrong but I think I remember something like that. If that's not it...Then take the #1 plug out and ball up a small piece of paper towel and push in into the plug hole(not too far). Then bump the ignition over slowly until the ball shoots out. This will be #1 TDC. Remove the cap and see where the rotor is pointing. This should be #1. Match that with the cap and install your wires from there.Hope this helps-Russell
  12. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    You have the right idea, just probably have a wire crossed with another. Double check everything, we've all screwed up this way before. A burned wire will make a miss too.
    CHECK THE WIRES ON AN OHM METER.
  13. tim_87
    tim_87 1/2 ton status
    Feb 2, 2001
    101
    louisiana
    i had the same problem on my 87. when the mechanic changed my distributer it changed the firing order on
    the cap. try what russell suggested it worked on mine
  14. newbe73
    Mar 14, 2002
    58
    SD
    hahha thanks everyone i got it to wok i was 180 degreas off thaks alot for all your help she runs so nice now
