Small Block Assembly Questions
Discussion in 'The Garage' started by merc359, Apr 23, 2005.
  1. merc359
    merc359 1/2 ton status
    Mar 25, 2005
    103
    Vancouver, BC. Canada
    Hey,
    I am putting together the bottom end of a small block chevy. I had the crank, rods, and pistons all professional assembled and installed but I am basically putting the rest of it together.
    A couple of questions:
    1. Oil Pump - How in God's name do I get the pickup into the oil pump? I am using a high volume pump and the pickup is not brazed to the main body of the pump. Is there a special tool to install it? Or must I hammer on it (gently) and hope that it doesn't damage the pickup tube?
    2. Another Oil Pump Question - Is there no gasket between the oil pump and the actual piece it bolts to? Does the lack of gasket result in a loss of power?
    3. Yet another Oil Pump Question - Can you tell I am paranoid about the oil pump? I got the steel shaft and sleeve for the high volume pump, but it appears to just "rest" in the slow of the oil pump. Now, i know that, technically, it is between the distributor the oil pump and it is not going anywhere, but stock ones use a round nylon clip to hold it in place. Do the steel shafts just "rest" there?
    4. Oil Filter Screw-in Adapter - I am putting the adapter back on as the machine shop took it off. This is the piece that the oil filter actually screws onto. This may be a stupid question, but there are two ways it can bolt on. Is there a correct way? There actual piece has two bolts that go into the block, the threaded piece for the oil filter, and some small inlet? outlet? on it as well. What side does that go on? The crank side or the ...outside side of the motor....sorry that sounds crazy...
    Any help would be greatly appreciated.
  2. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    There is a ool to kinda "press" the tube in te pump. kinda like a big wrench thats bent up
  3. 79chevyk10
    79chevyk10 1/2 ton status
    Dec 14, 2003
    612
    Central Coast
    Oil pump pick up tube is a press in. Try heating up the pump body and installing the pick up tube.
    No, there is no gasket between the main cap and the oil pump.
    The "adaptor" that you are talking about is the oil pump pressure relief valve, don't believe is matters what way it goes, but if it is any help I installed mine towards the block with no problems.
  4. merc359
    Mar 25, 2005
    103
    Thanks for that. That pretty much answers all the questions.
    The only thing I am still wondering about is the free-floating oil-pump drive shaft that does not clip it. Every time I rotate the engine upside down on the stand it falls out and sends me into a rage. Shouldn't there be a clip?
  5. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Its held in by the plastic clip at the oil pump and the distributor holds the other end in place....there is NO clip at the top
  6. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    that plastic bushing on the oil pump to the pump shaft should hold it but you may have to just drop it in after you are ready to button it up. THere is no need for a gasket on the main cap, whats it gonna do spring a leak an spray out of the motor? :D
  7. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    No, it is the oil filter bypass. It is meant to let oil flow if the filter becomes clogged. Correct way? I can't say sorry. The Oil Pump pressure relief valve is part of the pump.
  8. Ryan B.
    Jul 18, 2001
    5,693
    CA
    yep hammer in the oil pump pickup tube. set the pickup clearance to the bottom of the pan.
    then you can weld a small bead on the pickup tube and oil pump to ensure that it will not move ever.
  9. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
  10. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    If I am reading this correct, the steel sleeve that is pinned on the bottom of the shaft will keep the shaft on the pump...And the shaft will fall away from the pump when you flip the engine over without the distributor in. But won't fall out of the engine.
    If you look at the bottom of the distributer, there is a pocket to align and hold the shaft to the distributor. I just did this this week, actually just broke the engine in tonight and it works great and pegs the oil preasure gauge.
  11. short sub
    short sub Registered Member
    Jan 17, 2005
    98
    Sealy Texas
    hey put the p/u ass. in the freezer for a while- it will shrink and tap right in for ya.
  12. merc359
    Mar 25, 2005
    103
    Closed
    Thanks for all the help. All the questions I had are answered.
    That freezer trick is ABSOLUTELY GOLDEN. After pounding the holy hell out of it I stuffed it in the deep freeze for an hour, walked out, slipped it in LOOSELY into the pump and when it expanded it lodged itself in there excellently. I have the Moroso pickup for my Moroso oil pan so it also has the two bracket arms that bold to the pump house. That bad boy isn't going anywhere now. Thanks for the tips.
  13. dyeager535
    26,982
    191
    Oven works good for installing the timing chain gear on the crank too. :)
  14. merc359
    Mar 25, 2005
    103
    Another good idea
    Coincidentally, the crank gear is the only thing holding up my project. I'll stuff that bad boy in the oven for a bit and see how things go.
    I wonder if there is any risk of losing temper to the steel on the gears by doing that?
  15. rpellicer
    rpellicer Registered Member
    Dec 20, 2004
    38
    Susanville, CA
    Hehe... wives must be irritated :angry1: , bad enough we monopolize the garage, then they find parts in the kitchen appliances too!
  16. dyeager535
    26,982
    191
    I suspect that low of a temp isn't going to hurt the temper of steel, if it even is tempered.
  17. merc359
    Mar 25, 2005
    103
    Hah hah
    Yes, the wife is understanding. When I last put my headers with spray-on ceramic coating in the oven she was ....well....less than enthused......
