small block big block conversion
Discussion in 'The Garage' started by biggun79b, Jan 11, 2006.
  1. biggun79b
    biggun79b Newbie
    Jan 11, 2006
    3
    liberty nc
    i have a 86 blazer full size has a 350 with 700r with 208transfer case changing to big block 454 what am i going to have to change if any thing
  2. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    Nothing, pull sbc out, stick bbc in. You will have to correct the exhaust pipe but that should be about it, oh and maybe do something about the lower radiator fitting size.
  3. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    larger radiator,
    different radiator top plate support
    lower hose changes a tad
    dist
    alternator
    flywheel
    motor mounts
    starter
    shoud all work, the water pump, and brackets are different though
    bigger gas tank
    more brakes
    and rent some space cause your smile will be huge!
  4. biggun79b
    biggun79b Newbie
    Jan 11, 2006
    3
    liberty nc
    Is ThE 700r Going To Handle The Big Block And Is There Any Thing I Have To Change On The Drive Train For Hook Up AS FAR AS LENGHT DIFERANCE BETWEEN TEH SMALL BLOCK AND BIG BLOCK AND HOW ABOUT THE DETENT CABLE IS THAT GOING TO HOOK UP
  5. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    if you drive in moderation...the yes the 700r4 should be ok, if its a stock motor with penut heads then its not a monster anyways, but the diffrerence will be huge.
    i have only run a t-400 behind my big blocks, for the cable qestion i cant help
    on thing to add though is that trucks and subs came with big blocks and small blocks, so its a faily straight forward swap. I would look into a reliable, recomended tranny shop to build you a qulity unit, also at the minimum add a cooler and a temp guage and NO nuetral drops,
    I would venture to say the rear axel would go first if you drive hasty with the big block :)
  6. biggun79b
    biggun79b Newbie
    Jan 11, 2006
    3
    liberty nc
    Thanks For The Help Got Coller And Guage Now And Axles Will Be Next If I Can Find Some 3/4 Tons That Is And I Would Like A 4 Speed If I Could Find One In My Area Most On Here Are To Far Out But Thanks For Teh Replies Tey Helped Alot
  7. hero
    hero Registered Member
    Oct 21, 2002
    65
    Omaha, NE
    Make sure your torque convert bolt pattern is the same....before you drop the engine in.
