Small Block/Big Block weight issue
Discussion in 'The Garage' started by 1HighK5, Mar 24, 2005.
  1. 1HighK5
    1HighK5 1/2 ton status
    Feb 7, 2005
    140
    New York
    I know this question has probably been asked a million times but I can't seem to find the answer, Not to good at look'n. Any way what is the weight difference between a Big Block and Small block and will it make my lift sag if I put a Big Block in my truck. The 305 is almost dead I can't help but be a "Throttle Jockey"
  2. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
  3. 1HighK5
    Feb 7, 2005
    140
    New York
    Thanks for the answer I really want the Big Block I got a HEAVY foot.
  4. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    SBC = 585 lbs.
    BBC = 685 lbs.
  5. 1HighK5
    Feb 7, 2005
    140
    New York
    Thanks for the numbers
  6. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    alum heads and intake=SBC
  7. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    :crazy:
    ditch some junk, ac brackets/compressor and move the battery back... "free"
    alum heads are $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$:crazy:
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i have seen 571 posted as average fully dressed sbc engine, with or without aluminum anything i dunno
    i cant believe ive never weighed an engine yet, ive weighed a 2wd CH465(180lbs complete without bellhousing), and 12 bolt(75lbs bare housing) and some other items but never an engine yet, humm
    bare longbed 2wd pickup frame with front susp cradle minus arms spindles springs, 200lbs
    some day.. hum,.
  9. retroblazer
    retroblazer 1/2 ton status Premium Member
    Nov 30, 2003
    280
    148
    Gustine
    It all depends what you're doing with it. I have thought about doing a LS1 in my race blazer just to get another hundred pounds off the front end over my current 400. Still, it's hard to beat the 400 on a cost basis vs. changing over to the big-block.
  10. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    when I dropped in my big block, it dropped the nose a little over 1/4"
