Small Block Chevies... Vortec, LT1, LS1, LS6, etc...
Discussion in 'The Garage' started by 350350, Dec 18, 2003.
  1. 350350
    350350 1/2 ton status
    Sep 25, 2003
    939
    USA
    I have some random questions about the when and what of the changes to the small block as the Vortec, LT1, and LS designs rolled out... I'll toss them out randomly, although they are, of course, all cosmically intertwined. /forums/images/graemlins/1zhelp.gif
    [​IMG] What year did the Vortec 305/350 debut?
    [​IMG] What was different about the Vortec as opposed to the TBI block? I know about the EFI changes, but it seems like I recall the block and/or heads changed slightly. Water pump and front block face maybe???
    [​IMG] When did the Vortec engines get replaced with the LS-Style blocks, like the 5.3L, 5.7L, and 6.0L Vortecs? What year in trucks, and did vans change the same year or did the older block live longer in the vans???
    [​IMG] The LT1... A car thing I know... But when the LT1 came out it was significantly different than the old SBC. It had a completely different front block face, and the reverse flow cooling made significant changes to head and block passages. Did the Vortec engines use the LT1 block, or were they the old 'Tried and True' block style that older parts would interchange with???
    [​IMG] Are the LS-style engines iron blocks in the trucks? What are their actual engine designations, like the LS1 and LS6 are different engine configurations for cars... What about the truck designations?
    [​IMG] Do any of you have any of the above engines lying around that you would like to give me??? /forums/images/graemlins/laugh.gif
  2. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    1. 96 in the c/k trucks
    2. dont know about the block but it has Vortec heads which flow great for a stocky
    3. 99 for trucks dont know about vans though
    4. not the lt-1 block
    5. I know the 6.0L is all aluminum dont know about 5.3 or 4.8
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    6.0 is cast iron block/aluminum head IIRC, 4.8/5.3 are all aluminum (I'm pretty sure)
    The significant changes for the Vortec motors were the factory roller cams. Cars got them all the way back to '87, but they were not used in trucks across the board until 1996.
  4. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    '96 model year as stated above
    Mostly the fuel injection system. The Vortec heads use a different intake mounting bolt pattern than any other small block head.
    Gen 3 engines appeared in trucks for the '99 model year (4.8, 5.3 and 6.0l displacements). Vans carried over the old small blocks for a while.
    Vortec truck small blocks used a normal old style SBC block casting. The LT1 block is not really much different either. The water pump was driven by the camshaft, but the pump mounting to the block is the same as other SBC engines.
    All the Gen 3 truck engines (4.8, 5.3 and 6.0) used cast iron blocks until the 5.3 engine that is installed in the new extended Trailblazer/Envoy. All 4.8s and 5.3s used aluminum heads from the start, but the early 6.0 engines used cast iron heads. I believe all the heads are aluminum now. All pickup truck engines still use cast iron blocks. Not sure on the engine RPO codes off hand, but you can get them at GM Powertrain web site.
  5. Bhintz
    Mar 28, 2003
    1,341
    Roswell, Ga
    I beg to differ my dad as a 6.0L and its all aluminum but its also out of the denali truck which is a different setup than normal 6 liters
  6. 76SILVERADO
    76SILVERADO Registered Member
    Mar 1, 2003
    52
    AZ
    The LT1 block uses 6 bolts to mount water pump! not 4 like old school blocks.
  7. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Isn't the LS6 a 454 big block ???
  8. Ryan B.
    Jul 18, 2001
    5,693
    CA
    nah, the old school LS6 was the souped up 454 that came in chevelles back in the early 70's i believe...
    The new LS6 is a slightly re-designed and more powerful LS1. They put the LS6 in the new Z06 corvettes.
  9. Blazer1970
    1,600
    Old Mission, MI
    No, it's not all aluminum. Both the LQ4 and LQ9 6.0l engines have cast iron blocks and aluminum heads. There has never been a 6.0l Gen 3 engine with an aluminum block. Go to GM Powertrain web site , or look a little closer at your dad's truck.
  10. Bhintz
    Mar 28, 2003
    1,341
    Roswell, Ga
    I believe you, just listened to what my dad said and like always WRONG AGAIN /forums/images/graemlins/thumb.gif
  11. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    4.8 and 5.3 are iron block (excpet for the 5.3 in the ssr)
    ls1/ls6 are 5.7 and all aluminum
    6.0 is iron block
  12. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    LT1 uses the waterpump above the distributor and is cam driven..
    LS6 is the new corvette z06 engine.. LS-6 was the 454 big block rated at 450 hp..
  13. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    LS6 and LS1 are a head design. 6.0 i believe is an LS1 engine. it's listed on LS1tech.com
  14. 99firehawk
    Dec 15, 2002
    491
    ls1 and ls6 use 2 diffrent blocks kind of
    all 97-99 ls1s used the ls1 blocks
    some 00-02 ls1s recived ls6 blocks
    all 00-02ls1s recived ls6 intakes
    All ls6s came in the z06 vette with ls6 heads (cathedreal shaped ports)
    the 6.0 as well as the 4.8 and 5.3 are all LSx based, parts are interchangable, heads intake cam ect.
    6.0 also came with ls6 style heads but bigger combustion chambers, and are the hot ticket for FI guys
