small block crank question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Rix_Gotta_Blazer, Oct 27, 2002.
  1. Rix_Gotta_Blazer
    Rix_Gotta_Blazer 1/2 ton status
    Dec 13, 2001
    104
    Hollister, CA
    i am in the process of rebuilding my 1984 4 bolt 350. i am curious as to weather or not you can put a 2 bolt crank and rods out of a 1972 block into the newer 1984 350. is there any problem with the 2 bolt crank into the 4 bolt block? yur input is appreciated.
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    It will be fine.
    -- Mike
  3. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    2 bolt 4 bolt dont matter. The only difference is 1 piece rear main seal vs. 2 piece rear seal.
  4. Rix_Gotta_Blazer
    Dec 13, 2001
    104
    Hollister, CA
    thank you very much. i will proceed with the rebuild.
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    If you are going to be swapping crank and rods I would highly reccommend that you rebalance the engine since there is a balance difference between the early and later engines. You may get lucky and not have a problem (doubtful), but if it were me I sure would hate to have to pull the engine and tear it down and rebalance it once you have already had it built and installed.
  6. dyeager535
    26,980
    I'll have EVERY engine I build from here on out balanced.
    The shop that lost my connecting rods gave me new Eagle rods, and the crank had to have a LOT of material removed to get the thing balanced right. Thats a lot of stress that can be relieved from the engine for a minimal cost, something like $125 locally for a complete balance job.
