small block Q's?
Discussion in 'The Garage' started by nicotine, Jan 24, 2005.
  1. nicotine
    nicotine 1/2 ton status
    Jan 11, 2004
    116
    are all small block engine parts interchangable? parts like igntion? going form sb 400 to 350 or should i buy new igniton/ distributor?
  2. fire dawg
    fire dawg Registered Member
    Jan 24, 2005
    28
    new mexico
    the ignition and distributor are the same for both motors
  3. nicotine
    Jan 11, 2004
    116
    are all sb parts interchanable on each engine?
  4. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    All external parts are interchangeable, provided the heads have the proper accessoory holes, pre '86....400 heads have steam holes, 350 heads do not. The cam, timing gear, lifters and oil pumps exchange.
    The crankshaft, and connecting rods can be used with wooork/planning....(Except for the 400 rods into a 350, no reason for that)
    Anything more specific?
  5. akbound
    akbound 1/2 ton status
    Apr 20, 2004
    San Antonio
    balancer and flywheel/flexplate are NOT interchangable
  6. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    Missed that....What do you want to specifically recycle?
