Small block to Big Block
Discussion in 'The Garage' started by ck22, Jan 8, 2007.
  1. ck22
    ck22 Registered Member
    Jan 20, 2006
    23
    Dallas, TX
    I spun a crank bearing in my 400 SB. The 400 was the orginal engine, only mods are Edlebrock carb and points replaced with Petronix. A good friend is selling his 1968 bored out 30 over 427 BB. It puts out around 500hp 550 ftlbs of torqe:D . I know the engine mounts will fit the BB and that it will bolt right up to the 400 tranny. He's giving it to me at a great price if I want it. I'm lookoing for input and ideas on the swap and any upgrades if needed.
  2. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    I know all the accessory brackets won't swap over. So you will need those...
  3. ck22
    Jan 20, 2006
    23
    Dallas, TX
    I should be able to find those at the junkyard, right?
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    probably , or here on ck5 if you post up in the wanted section . You should have had a good 3 or 4 core radiator with the 400 , so you can use that .
    Get a big block fan shroud too .
  5. ck22
    Jan 20, 2006
    23
    Dallas, TX
    The rad. is a 4 core. The shrouds are diff. in sizes? Good to know!
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I am not sure on the trucks , but on big block cars it is different , I assume this carries over to trucks .
  7. diesel4me
    Jul 24, 2003
    17,540
    935
    Massachussetts
    Maybe in Florida.....but not here!
    Maybe....
    You might find them in your area,but here big blocks are scarce in junkyards,and they usually wont let you strip backets off even a blown up one here--they sell them online for big $$$$$$!...you'd be better off buying an aftermarket setup from Jegs or Summit,then you'll have all the right pulleys,and wont be ripping your hair out trying to find that one of a kind pullley you need,etc..you could even go serpentine if desired..:crazy:
    Oh yeah--one other thing you'll need with a BBC --plenty of money, for TIRES..especially REAR tires!..:wink1:
  8. ck22
    Jan 20, 2006
    23
    Dallas, TX
    What about the front springs? I read in resto. mags that only 2WD trucks came with big blocks, at in 1972. I probably replace them anyway but I should know this.
  9. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    If you still have stock springs than it's going to want to squish them down a little bit. You are adding a few hundred pounds. As long as you don't get any tire rubbing, at least it will ride nice.
    If you go lift springs I wouldn't worry about it then, infact it will also make them ride a bit better.
  10. SkysTheLimit
    SkysTheLimit 1/2 ton status
    May 23, 2003
    530
    Tampa, FL
    I'm in Tampa and going through this very same issue. If you find a junkyard that A) has what you need and B) will sell them cheap, let me know!!
    I'm trying to work a deal with a member here for some but if that falls through, i'll try local.
    Good to find some local boys!
  11. ck22
    Jan 20, 2006
    23
    Dallas, TX
    I have the orginal inverted front leaf springs, not coil springs that come on 2WDs. Would it do the same thing?
  12. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I doubt they are inverted . Stock Blazer fronts sat kinda flat . 10 bucks says they are sagging .
  13. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    you shoudl replace your motor mounts with the competition style from ord.
  14. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I know...
    Regardless of the type of spring, it's going to sag with more weight on top of it. It's what springs do, this is a factor that will always be in play. The variable is how much sag or squishyness is acceptable and still safe.
  15. ck22
    Jan 20, 2006
    23
    Dallas, TX
    So change the springs, got it!
    As for the mounts, I have engery suspunsion polys, motor and trans, still unwraped. I also added new body mounts, what a pain in the --- that was.
  16. PsRumors
    PsRumors 1/2 ton status
    Nov 11, 2006
    626
    Cartersville, GA
    I had no negative effects on the springs with the added weight of the 454 in my Suburban. Unless you just want to do it now I don't think it is neccessary.
    Most people don't go changing springs when they hang a heavy bumper and winch off the front and with the leverage out front you are probably about equal.
    Also, springs can be changed after the fact if you don't like it, not like it has to be done now.
    My 2 cents.
  17. Chevy305
    Jan 23, 2006
    11,228
    485
    New Hampshire
  18. PsRumors
    Nov 11, 2006
    626
    Cartersville, GA
  19. Chevy305
    Jan 23, 2006
    11,228
    485
    New Hampshire
    Well yes and no... Most standard lift springs are stifffer than stock. If you want a softer ride than stock I don't think you will ever get that out of lift springs. But you can come darn close with certain types of springs.
    I think someone else can elaborate better than I can...
