Small box on speedo cable?
Discussion in 'The Garage' started by uberbeans, Jun 21, 2006.
  1. uberbeans
    uberbeans 1/2 ton status
    May 14, 2004
    564
    Jacksonville, Florida
    What is the small box on the side of a 205 transfer case that the speedo cable goes through?
  2. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    more than likely it sounds like a gear reduction/multiplier that is used to correct speedo calibrations based on larger tires or different gear ratios that came from the factory. It should have a number on the side like 1.05 or something that will indicate the percent of reduction.
  3. uberbeans
    May 14, 2004
    564
    Sounds right. Does anyone know how to calibrate one for 4:88's?
  4. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    there was a guy I got hold of WAAAAAAAAAAAAAAAAAAY back.. he said send him yours.... and he will re-calibrate it for $75....
    I said EFF IT!!! I use my pda....
    I use Speed Sentry.... if you click the sun button.. it is white with black numbers....
    cool part is you can tell it MPH..
    also tracks your miles and all and is accurate as hell....
    Longitude and latitude
    buttons in order
    day/night
    curr speed / alarm speed
    altitude
    compass with bearing
    speedo
    satellites in use
    also my gps setup....
    Ipaq 3850
    Double Sleeve Jacket
    PCMCIA to CF converter
    GlobalSat 307B CF GPS
    GlobalSat AT-65 Antennea
    Destinator PN software
    just got a external pcmcia drive setup... 20gb laptop drive in it at the moment..... the thing hangin on the left is a fm transmitter... so my directions come over the speakers in the truck... also can play mp3's or watch a movie.. (dont recommend the movie part driving a truck with wide bias hawgs as you may hit someone :haha: )
