SMALL engine to 465 questions
Discussion in 'The Garage' started by BigOrange90Jimmy, Nov 6, 2003.
  1. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    What is the SMALLEST GM engine I can mate up to a 465?
    My little Suzuki doesn't even have enough power to get out of it's own way, so I'm wanting to solve that little problem.
    I know a 4.3 would work since it's 350 minus two cylinders, but I was hoping there was something smaller than that that would work.
    What I'm shooting for is something that can handle some higher RPM's (roughly 5-7K without blowing apart).
    Or unless there was a GM 4 or 5 speed offered in the S-series trucks that had a good and low first gear, that would be great also.
  2. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    if u want small, just put a toy engine in front of ur 465...
    like this
    j
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    all chevy belhousings are the same so you can bolt it up to a chevy 4cylinder if you want to /forums/images/graemlins/thumb.gif
  4. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    the 2.8 had a different bellhousing. but you're right the little 2.5 4 cyl. does share the same pattern.
    the swap for the sammies is the 1.6L 16 valve sidekick motor. my buddy just finished this swap in his. he also has 4 to 1 in the case.
  5. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    go pull the 140 hp. mercruiser 4-cyl out of a boat. commonly found in mid 70's to mid 80's 15-18' runabouts. it is a chevy motor, but you get all the heavy duty marine accesories, including the carb. plus its a big 4, with both low end torque to get the boat moving, and high end to keep it going. you could get them for real cheap if you know where to look.
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    ive got a history page saved from the internet all about the 4 cyl iron duke 2.5L GM engines, 80-up were normal 'modern' crossflow 2.5L
    AMC and Jeep and GM used these engines, 79 and older were some wierd intake setup, the original iron dukes, 82-86 firebirds got some of the iron dukes, mostly with 4 speed iron side loader tranny, i helped put a 400 sbc into oneof these birds a couple years ago, makes for a fast cheap car
  7. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    is the 2.5 fuel injected?
    that's my biggest concern is getting rid of the carb.
    i would love to put a 1.6 in it, but no one local has one for the price i'm willing to pay, plus i have to get a $250 adapter kit for it, plus wiring harness mods ($400), and whatever else it may need.
  8. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    my dads 87 s-10 has the fuel injected 2.5L. you wanna buy it? LOL
    yeah my buddy has ALOT into his 1.6L swap
  9. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    The older GM 4cyl. had a 90* bell housing pattern but I think the later models ( the Pontiac Iron Duke ) had a 60* pattern - this may only be true in a front wheel drive application . I am not really sure on this , I just wanted to point out that it may be possible that there could be bell housing differences in the GM 2.5's .
    I would PM U2SLOW to know for sure .
    Good luck , Tom
