small lift for a 72
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by hailey, Nov 28, 2002.
  1. hailey
    hailey Registered Member
    Aug 25, 2002
    32
    chattanooga, tn
    Does any one know who makes a 2 or 3 inch suspension lift? I want to run 33s, but don't really want to go to the trouble of a 4 inch and possibly having to do everything that goes along with it (steering, driveshaft...). It is my daily driver, but will see mud and trails. thanks.
    hailey
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    rancho makes a 2.5in lift thats what im running and am very happy with it /forums/images/graemlins/smile.gif
  3. naranja72
    naranja72 1/2 ton status
    Jan 6, 2002
    110
    vancouver, bc, canada
    Offroad Design carries a 2" lift from Tuff Country, it's an EZ Ride system which means a softer ride. That's what I'm going to be putting on my truck. Hope this helps.
    Marc
  4. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    I don't know about first gens, but my 74 had saggy butt so I went with a 3" in back and 2" in front from Tuff country EZ rides... /forums/images/graemlins/thumb.gif
  5. PGL4VT
    PGL4VT Registered Member
    Feb 10, 2002
    71
    Roanoke, Virginia
    I put a 2.5" Skyjacker on mine with springs all the way around. It looked like the rear was sagging even though it wasn't. It appears to be because the front fenders are cut higher at the top of the arch. The lift kind of magnified that look so I added a 1" block in the rear in addition to the springs. Looks level now and I run 33's on a 15 by 10 rim.
  6. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    I did a 4" kit and did no driveshaft modifications. I did use a lifted steering arm however. For 33s you almost don't even need a lift on the '67-'72s If you use the right wheel and tire combo. it can be done. Otherwise I would recommend to you a 2.5" kit by Tuff country, Trailmaster, or even Superlift.
  7. ChevyDrivnRdneck
    ChevyDrivnRdneck 1/2 ton status
    Nov 25, 2002
    714
    Modesto, Ca
    I put a 4 inch on my 71 K20 with no modifications at all. Brake lines, steering arm are all stock and I haven't had any problems at all. /forums/images/graemlins/truck.gif /forums/images/graemlins/usaflag.gif
  8. rrent
    rrent 1/2 ton status
    Jun 10, 2001
    174
    Round Rock, Texas
    If you put those 33's on a set of 8" rims you shouldn't need any lift at all.
