smallblock driver and psgr side heads interchangeable?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Jed, Jun 14, 2002.
  1. Jed
    Jed Registered Member
    Nov 3, 2001
    60
    Alberta, Canada
    Does anyone know if smallblock heads are similar enough that they could be swapped or substituted? (e.g. passenger side head put on the driver's side of the block).
    I'd guess that accessory mounting points might not be there but the head bolt pattern and intake/exchaust valve ordering looks symmetric.
    If they are the same, are there any drawbacks to substituting one for the other?
    Thanks in advance.
  2. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    You might have to swap out a coolant passage block off plug and a heat sensor, but other than that they are exactly the same. Even the accessory mounting holes are the same.
    Mike
  3. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Yup, the same.
  4. Jed
    Nov 3, 2001
    60
    Alberta, Canada
    Thanks. There goes that theory - I wonder why my heads only have 2 accessory mouting points on the front instead of 3? All the aftermarket smallblock pwr steering pump brackets for use with headers I've looked at have 3 holes. Mine appears to be missing the one up by the valve cover near the intake manifold. Guess I should look at the casting number.
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Sounds like you've got a really old head there. Somewhere way back in the history of the small block, they didn't have a requirement for the 3rd hole.
  6. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    I interchanged mine last week when I was completing my top end rebuild.
