Smaller distributor available for 350?
Discussion in 'The Garage' started by PJTPW, Jul 18, 2005.
  1. PJTPW
    PJTPW 1/2 ton status
    Jan 14, 2003
    226
    Moab, Utah
    I'm looking for options for a smaller diameter, shorter, distributor for my buggy. I'm trying to get the motor back further and lower. What are my options?
    I'm kind of new to the GM stuff :D
    Ryan
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Most guys run smaller diameter caps for tunnel ram and blower fitments . Mallory makes a nice one . Another alternative is an old points unit converted to electronic ignition .
    Now if you want short height , this is it :D
  3. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    Mallory makes the smallest dia distributor I've seen but it's not shorter. Maybe check out distributors for blower applications to see if something smaller is offered.
  4. mrk5
    Apr 20, 2004
    12,341
    1,047
    Northern Colorado
    I have the MSD Pro-Billet distributor that is a direct replacement for HEI. It is about the diameter of typical points style distributor. It is not shorter, though.
  5. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    i second mallory- good dist and ignition stuff
    i have one
  6. Mad-Dog
    Mad-Dog 1/2 ton status
    Mar 20, 2005
    548
    Ocklawaha,Fl
    If the smallest/shortest distributor is still too big/tall then you could use a crank-fired system with a distributorless ignition (1 coil per cylinder).
    you would have to modify a distributor by cutting it off at the top of the collar where it is held into the manifold, this would serve only to hold the oil-pump driveshaft in place.
    Then weld a small cap over the top of the modified dist. to seal the elements out as they would run down between the shaft and housing.
